Datasheet ADL5391 (Analog Devices) - 8
DescriptionDC to 2.0 GHz Multiplier
Pages / Page15 / 8 — ADL5391. Data Sheet. 0.20. X ± INPUT = ±100mV p-p, @ 200MHz Y ± INPUT = …
File Format / SizePDF / 524 Kb
ADL5391. Data Sheet. 0.20. X ± INPUT = ±100mV p-p, @ 200MHz Y ± INPUT = 1.0V DC DIFFERENTIAL. 0.15. 0.10. 0.05. Y = 1. (V). Bm). 3 (. UT O
ADL5391 Data Sheet 0.20 X ± INPUT = ±100mV p-p, @ 200MHz Y ± INPUT = 1.0V DC DIFFERENTIAL 0.15 0.10 0.05 Y = 1 (V) Bm) 3 ( UT O
ADL5391 Data Sheet 0.20 30 X ± INPUT = ±100mV p-p, @ 200MHz Y ± INPUT = 1.0V DC DIFFERENTIAL 0.15 25 0.10 20 0.05 Y = 1 (V) Bm) UT d P 0 15 3 ( UT O IP W O –0.05 Y = 0.5 10 –0.10 5 –0.15 –0.20 0 24.5 25.5 26.5 27.5 28.5 29.5 30.5 31.5 32.5
014
0 500 1000 1500 2000
016
TIME (ns) FREQUENCY (MHz)
06059- 06059- Figure 9. Small Signal Pulse Response Figure 12. OIP3 vs. Frequency Pin 0 dBm, Y = 1 V dc, 0.5 V dc
0.05 0.04 0.03 +85°C, X = +1 +85°C, X = –1 0.02 –40°C, X = –1 –40°C, X = +1 ) +25°C, X = –1 10MHz 0.01 200MHz DC +25°C, X = +1 (V F 0 F DI W –0.01 V V 400MHz DI DI 600MHz Bm/ Bm/ –0.02 10d 10d –0.03 30MHz –0.04 20MHz
094
–0.05 –0.05 –0.04 –0.03 –0.02 –0.01 0 0.01 0.02 0.03 0.04 0.05
06059- 021
YDIFF (VDC)
06059- Figure 10. Harmonic Distortion at 10 MHz and 200 MHz; Figure 13. Z (W) Offset Over Temperature 0 dBm Input to X (Y) Channels
28 45 X = 0V, Y = 1V 26 40 24 ) X = Y = 1V DC 22 (V 35 z) SET F 20 H X = Y = 0V F O V/ 30 V (n E 18 D SN RAG 16 E 25 AV 14 20 12 10 15 –40 –15 10 35 60 85
015
200 400 600 800 1000 1200 1400 1600 1800 2000
019
TEMPERATURE (°C) FREQUENCY (MHz)
06059- 06059- Figure 11. X (Y) Offset Drift vs. Temperature Figure 14. Noise vs. Frequency Rev. A | Page 8 of 15 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Basic Theory Calibration Basic Connections Multiplier Connections Matching the Input/Output Wideband Voltage-Controlled Amplifier/Amplitude Modulator Squaring and Frequency Doubling Use as a Detector Evaluation Board Outline Dimensions Ordering Guide
