Datasheet AD835 (Analog Devices) - 8
Description250 MHz, Voltage Output 4-Quadrant Multiplier
Pages / Page14 / 8 — AD835. Data Sheet. 10MHz. +1V. GND. 10dB/DIV. –1V. 30MHz. 20MHz. 500mV. …
RevisionE
File Format / SizePDF / 259 Kb
AD835. Data Sheet. 10MHz. +1V. GND. 10dB/DIV. –1V. 30MHz. 20MHz. 500mV. 10ns. 50MHz. 100MHz. 150MHz. CMRR (dB). 10M. 100M. FREQUENCY (Hz)
AD835 Data Sheet 10MHz +1V GND 10dB/DIV –1V 30MHz 20MHz 500mV 10ns 50MHz 100MHz 150MHz CMRR (dB) 10M 100M FREQUENCY (Hz)
00883-009 00883-012 Figure 9. Large Signal Pulse Response at W Output, RL = 150 Ω, CL ≤ 5 pF, Figure 12. Harmonic Distortion at 10 MHz; 10 dBm Input to X or Y Channels, X Channel = ±1.0 V, Y Channel = ±1.0 V RL = 150 Ω, CL = ≤ 5 pF
50MHz 0 20 40 10dB/DIV 100MHz 150MHz 60 CMRR (dB) 80
00883-010 00883-013
1M 10M 100M 1G FREQUENCY (Hz)
Figure 10. CMRR vs. Frequency for X or Y Channel, RL = 150 Ω, CL ≤ 5 pF Figure 13. Harmonic Distortion at 50 MHz, 10 dBm Input to X or Y Channel, RL = 150 Ω, CL ≤ 5 pF
0dBm ON SUPPLY X, Y = 1V 100MHz PSSR ON V+ –10 –20 –30 200MHz 300MHz –40 10dB/DIV PSSR (dB) –50 PSSR ON V– –60
00883-011 00883-014
300k 1M 10M 100M 1G FREQUENCY (Hz)
Figure 11. PSRR vs. Frequency for V+ and V– Supply Figure 14. Harmonic Distortion at 100 MHz, 10 dBm Input to X or Y Channel, RL = 150 Ω, CL ≤ 5 pF Rev. E | Page 8 of 14 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BASIC THEORY SCALING ADJUSTMENT APPLICATIONS INFORMATION MULTIPLIER CONNECTIONS WIDEBAND VOLTAGE-CONTROLLED AMPLIFIER AMPLITUDE MODULATOR SQUARING AND FREQUENCY DOUBLING OUTLINE DIMENSIONS ORDERING GUIDE
