Datasheet XDPL8219 (Infineon) - 2
ManufacturerInfineon
DescriptionDigital Flyback Controller IC
Pages / Page45 / 2 — XDPL8219 Digital Flyback Controller IC. XDP™ Digital Power. Description. …
Revision01_01
File Format / SizePDF / 749 Kb
XDPL8219 Digital Flyback Controller IC. XDP™ Digital Power. Description. Output. AC Input. voltage. Figure 1
XDPL8219 Digital Flyback Controller IC XDP™ Digital Power Description Output AC Input voltage Figure 1
link to page 43 link to page 41 link to page 2 link to page 43 link to page 41 link to page 43 link to page 42 link to page 41 link to page 43 link to page 44 link to page 42 link to page 44 link to page 44 link to page 42 link to page 43
VCC ZCD GD CoolMOS™ HV Flyback CS Controller IC GND UART FB Feedback Circuit
Figure 1 Typical Application for XDPL8219
Note: The
SSR CV
output in
Figure 1
should not be used to directly drive the LEDs. For LED lighting application, it should be converted to constant current output by a second-stage DC-DC switching or linear regulator.
Product type Package Marking Firmware version Ordering code
XDPL8219 PG-DSO-8 L8219 0.0.1.1 SP002990946
The XDPL8219 is a high performance
SSR CV
controller for the high power factor flyback converter. The device operates in
QRMn
to maximize the efficiency and minimize the
EMI
, across a wide load range. It enters
ABM
at light load to prevent audible noise and at the same time achieving no-load standby power as low as < 100 mW. The XDPL8219 detects the input voltage type (AC or constant DC) and adapts its proprietary voltage mode pulse modulator accordingly to enhance the system performance. For AC input, it adapts the pulse modulation to achieve high
PF
(>0.9) and low
THD
(<10%) over wide input and load range. For constant DC input, it adapts the pulse modulation which dithers the switching frequency to lower the EMI over the entire operating range. Infineon's innovative digital power platform maximizes the XDPL8219 performance in a standard DSO-8 package. The XDPL8219 transmits
UART
signals to report the estimated input voltage, estimated line frequency, controller temperature, last error code and input voltage loss indication. In addition, it provides the maximum design flexibility and performance optimization with parameter configuration via UART. Infineon offers the programming tools including an user friendly
Graphic User Interface
for
Personal Computer
s, to configure the XDPL8219 parameters. The device has a built-in 600 V HV start-up cell and also a proprietary start-up sequence to ensure a fast output voltage rise with minimal overshoot. Data Sheet 2 Revision 1.1 2020-08-26 Document Outline Features Product validation Potential applications Description Table of contents 1 Pin configuration 2 Functional block diagram 3 Functional description 3.1 Startup 3.2 Regulated mode 3.3 Operation cycle 3.4 Line synchronization 3.5 Enhanced power quality 3.6 Switching frequency dithering for constant DC input voltage 3.7 Configurable gate voltage rising slope at GD pin 3.8 UART reporting 3.9 Input voltage and output voltage estimation 3.9.1 Output voltage estimation 3.9.2 Input voltage estimation 3.10 Protection features 3.10.1 Primary MOSFET overcurrent protection 3.10.2 Output undervoltage protection 3.10.3 Output overvoltage protection 3.10.4 Transformer demagnetization time shortage protection 3.10.5 Minimum input voltage startup check and input undervoltage protection 3.10.6 Maximum input voltage startup check and input overvoltage protection 3.10.7 VCC undervoltage lockout 3.10.8 VCC undervoltage protection 3.10.9 VCC overvoltage protection 3.10.10 IC overtemperature protection 3.10.11 Other protections 3.10.12 Protection reactions 3.11 Debug mode 4 List of Parameters 5 Electrical Characteristics and Parameters 5.1 Package Characteristics 5.2 Absolute Maximum Ratings 5.3 Operating Conditions 5.4 DC Electrical characteristics 6 Package Dimensions 7 References 8 Revision History Glossary ABM ADC BOM CCM CRC CV DCM EMI FB GUI HID IC IIR OCP1 OTP PCB PC PFC PF PWM QRM1 QRMn RAM SSR THD UART USB UVLO Disclaimer
