Datasheet DA9130-A (Dialog Semiconductor) - 22
Manufacturer | Dialog Semiconductor |
Description | High-Performance, 10 A, Dual-Phase DC-DC Converter |
Pages / Page | 44 / 22 — DA9130-A. High-Performance, 10 A, Dual-Phase DC-DC. Converter. Table 14: … |
File Format / Size | PDF / 1.0 Mb |
DA9130-A. High-Performance, 10 A, Dual-Phase DC-DC. Converter. Table 14: Interrupt Registers Except for Power Good Status
![DA9130-A High-Performance, 10 A, Dual-Phase DC-DC Converter Table 14: Interrupt Registers Except for Power Good Status](https://www.rlocman.ru/datasheet/img.php?di=169953&p=21)
DA9130-A High-Performance, 10 A, Dual-Phase DC-DC Converter Table 14: Interrupt Registers Except for Power Good Status Register Description
E_<name> Read-only interrupt event register 0: No interrupt 1: Interrupt occurred
Cleared after being written to I2C
. Set until IRQ is removed. M_<name> Interrupt mask register 0: Not masked 1: Masked. No IRQ signal sent. Event register (E_<name>) is updated.
Table 15: Interrupt Registers for Power Good and Temp Warning Status Register Description
PG<x> Buck<x> power good status. Asserted as long as the buck<x> output voltage is in range (under-voltage threshold < buck output voltage < over-voltage threshold) 0: Not power good 1: Power good M_PG<x>_STAT Power good status interrupt mask register 0: Not masked 1: Masked. No IRQ signal sent. Power good status register (PG<x>) is updated TEMP_WARN Asserted as long as the thermal warning threshold (TWARN) is reached 0: Junction temperature is below TWARN 1: Junction temperature is above TWARN M_VR_HOT Temperature warning status (TEMP_WARN) interrupt mask register 0: Not masked 1: Masked. No IRQ signal sent. Temperature warning status register (TEMP_WARN) is updated I2C
Condition
TJ > TWARN TJ < TWARN Write · Clear GPIO is cofigured as nIRQ · M_TEMP_WARN = 0 Over-voltage · M_PG#_STAT = 0 Target Voltage Under-voltage VOUT Status Reg TEMP_WARN Event Reg E_TEMP_WARN
0 1 0
IRQ
Not
Status Reg Masked PG# Active-High Setting (GPIO#_POL = 0) GPIO (nIRQ) Active-Low Setting (GPIO#_POL = 1)
Figure 8: Interrupt Operation Example Datasheet Revision 1.0 31-Aug-2020
CFR0011-120-00 22 of 44 © 2020 Dialog Semiconductor Document Outline General Description Key Features Benefits Applications System Diagrams Contents Table of Figures Table of Tables 1 Terms and Definitions 2 Pinout 3 Characteristics 3.1 Absolute Maximum Ratings 3.2 Recommended Operating Conditions 3.3 Thermal Characteristics 3.3.1 Thermal Ratings 3.3.2 Power Dissipation 3.4 ESD Characteristics 3.5 Buck Characteristics 3.6 Performance and Supervision Characteristics 3.7 Digital IO Characteristics 3.8 Timing Characteristics 3.9 Typical Performance 4 Functional Description 4.1 DC-DC Buck Converter 4.1.1 Switching Frequency 4.1.2 Operation Modes and Phase Selection 4.1.3 Output Voltage Selection 4.1.4 Soft Start-Up and Shutdown 4.1.5 Current Limit 4.1.6 Resistive Divider 4.1.7 Thermal Protection 4.2 Internal Circuits 4.2.1 IC_EN/Chip Enable/Disable 4.2.2 nIRQ/Interrupt 4.2.3 GPIO 4.2.3.1 GPIO Pin Assignment 4.2.3.2 GPIO Function 4.2.3.3 Chip Configuration Select (CONF) 4.3 Operating Modes 4.3.1 ON 4.3.2 OFF 4.4 I2C Communication 4.4.1 I2C Protocol 5 Register Definitions 5.1 Register Map 5.1.1 System 5.1.2 Buck1 5.1.3 Serialization 6 Package Information 6.1 Package Outlines 6.2 Moisture Sensitivity Level 6.3 Soldering Information 7 Ordering Information 8 Application Information 8.1 Capacitor Selection 8.2 Inductor Selection
