Datasheet DA9131 (Dialog Semiconductor) - 32
ManufacturerDialog Semiconductor
DescriptionHigh-Performance, Dual-Channel DC-DC Converter
Pages / Page53 / 32 — DA9131. High-Performance, Dual-Channel DC-DC Converter. 5.1.1. System. …
DA9131. High-Performance, Dual-Channel DC-DC Converter. 5.1.1. System. Table 20: SYS_STATUS_0 (0x0001). Bit. Symbol. Description
DA9131 High-Performance, Dual-Channel DC-DC Converter 5.1.1 System Table 20: SYS_STATUS_0 (0x0001) Bit Symbol Description
[2] SG Asserted as long as the enabled buck output voltage is in range [1] TEMP_CRIT Asserted as long as the thermal shutdown threshold is reached [0] TEMP_WARN Asserted as long as the thermal warning threshold is reached
Table 21: SYS_STATUS_1 (0x0002) Bit Symbol Description
[7] PG2 Asserted as long as the Buck2 output voltage is in range [6] OV2 Asserted as long as Buck2 hitting over-voltage [5] UV2 Asserted as long as Buck2 hitting under-voltage [4] OC2 Asserted as long as Buck2 hitting over-current [3] PG1 Asserted as long as the Buck1 output voltage is in range [2] OV1 Asserted as long as Buck1 hitting over-voltage [1] UV1 Asserted as long as Buck1 hitting under-voltage [0] OC1 Asserted as long as Buck1 hitting over-current
Table 22: SYS_STATUS_2 (0x0003) Bit Symbol Description
[2] GPIO2 GPIO2 status [1] GPIO1 GPIO1 status [0] GPIO0 GPIO0 status
Table 23: SYS_EVENT_0 (0x0004) Bit Symbol Description
SG caused event. Writing 1 action clear this bit into 0 if event source has [2] E_SG been released. TEMP_CRIT caused event. Writing 1 action clear this bit into 0 if event [1] E_TEMP_CRIT source has been released. TEMP_WARN caused event. Writing 1 action clear this bit into 0 if event [0] E_TEMP_WARN source has been released.
Table 24: SYS_EVENT_1 (0x0005) Bit Symbol Description
PG2 caused event. Writing 1 action clear this bit into 0 if event source has [7] E_PG2 been released. OV2 caused event. Writing 1 action clear this bit into 0 if event source has [6] E_OV2 been released. UV2 caused event. Writing 1 action clear this bit into 0 if event source has [5] E_UV2 been released. OC2 caused event. Writing 1 action clear this bit into 0 if event source has [4] E_OC2 been released.
Datasheet Revision 1.0 31-Aug-2020
CFR0011-120-00 32 of 53 © 2020 Dialog Semiconductor Document Outline General Description Key Features Benefits Applications System Diagrams Contents Table of Figures Table of Tables 1 Terms and Definitions 2 Pinout 3 Characteristics 3.1 Absolute Maximum Ratings 3.2 Recommended Operating Conditions 3.3 Thermal Characteristics 3.3.1 Thermal Ratings 3.3.2 Power Dissipation 3.4 ESD Characteristics 3.5 Buck Characteristics 3.6 Performance and Supervision Characteristics 3.7 Digital I/O Characteristics 3.8 Timing Characteristics 3.9 Typical Performance 4 Functional Description 4.1 DC-DC Buck Converter 4.1.1 Switching Frequency 4.1.2 Operation Modes and Phase Selection 4.1.3 Output Voltage Selection 4.1.4 Soft Start-Up and Shutdown 4.1.5 Current Limit 4.1.6 Resistive Divider 4.1.7 Thermal Protection 4.2 Internal Circuits 4.2.1 IC_EN/Chip Enable/Disable 4.2.2 nIRQ/Interrupt 4.2.3 GPIO 4.2.3.1 GPIO Pin Assignment 4.2.3.2 GPIO Function 4.2.3.3 Chip Configuration Select (CONF) 4.3 Operating Modes 4.3.1 ON 4.3.2 OFF 4.4 I2C Communication 4.4.1 I2C Protocol 5 Register Definitions 5.1 Register Map 5.1.1 System 5.1.2 Buck1 5.1.3 Buck2 5.1.4 Serialization 6 Package Information 6.1 Package Outlines 6.2 Moisture Sensitivity Level 6.3 Soldering Information 7 Ordering Information 8 Application Information 8.1 Capacitor Selection 8.2 Inductor Selection
