Datasheet AD8429 (Analog Devices) - 6
Description1 nV/√Hz Low Noise Instrumentation Amplifier
Pages / Page20 / 6 — AD8429. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL RESISTANCE. …
RevisionA
File Format / SizePDF / 668 Kb
AD8429. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL RESISTANCE. Parameter. Rating. Table 3. Package. θJA. Unit. ESD CAUTION
AD8429 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 THERMAL RESISTANCE Parameter Rating Table 3 Package θJA Unit ESD CAUTION
link to page 15
AD8429 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2. THERMAL RESISTANCE Parameter Rating
θJA is specified for a device in free air using a 4-layer JEDEC Supply Voltage ±18 V printed circuit board (PCB). Output Short-Circuit Current Duration Indefinite Maximum Voltage at –IN, +IN1 ±VS
Table 3.
Differential Input Voltage1
Package θJA Unit
Gain ≤ 4 ±VS 8-Lead SOIC 121 °C/W 4 > Gain > 50 ±50 V/gain Gain ≥ 50 ±1 V Maximum Voltage at REF ±V
ESD CAUTION
S Storage Temperature Range −65°C to +150°C Specified Temperature Range −40°C to +125°C Maximum Junction Temperature 140°C ESD Human Body Model 3.0 kV Charge Device Model 1.5 kV Machine Model 0.2 kV 1 For voltages beyond these limits, use input protection resistors. See the Theory of Operation section for more information. Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. A | Page 6 of 20 Document Outline FEATURES APPLICATIONS PIN CONNECTION DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ARCHITECTURE RG Power Dissipation REFERENCE TERMINAL INPUT VOLTAGE RANGE LAYOUT Common-Mode Rejection Ratio over Frequency Power Supplies and Grounding Reference Pin INPUT BIAS CURRENT RETURN PATH INPUT PROTECTION Input Voltages Beyond the Rails Large Differential Input Voltage at High Gain IMAX RADIO FREQUENCY INTERFERENCE (RFI) CALCULATING THE NOISE OF THE INPUT STAGE Source Resistance Noise Voltage Noise of the Instrumentation Amplifier Current Noise of the Instrumentation Amplifier Total Noise Density Calculation OUTLINE DIMENSIONS ORDERING GUIDE
