Datasheet AD8226 (Analog Devices) - 10
Description | Wide Supply Range, Rail-to-Rail Output Instrumentation Amplifier |
Pages / Page | 28 / 10 — AD8226. Data Sheet. 2.5. +0.02V, +2.0V. VREF = +1.35V. +1.35V, +1.9V. … |
Revision | D |
File Format / Size | PDF / 1.6 Mb |
AD8226. Data Sheet. 2.5. +0.02V, +2.0V. VREF = +1.35V. +1.35V, +1.9V. 2.0. REF = +1.35V. 1.5. G A. +0.02V, +1.3V. +2.68V, +1.2V. 1.0
AD8226 Data Sheet 2.5 2.5 +0.02V, +2.0V VREF = +1.35V +1.35V, +1.9V 2.0 +0.02V, +2.0V V ) 2.0 +1.35V, +1.9V ) REF = +1.35V (V (V E 1.5 E G A AG 1.5 T +0.02V, +1.3V T L +2.68V, +1.2V L 1.0 O VO +0.02V, +1.3V V +2.67V, +1.3V E V +2.4V, +0.8V VREF = 0V D REF = 0V 1.0 DE O O 0.5 +2.4V, +0.8V -M M +0.02V, +0.3V +2.68V, +0.3V N N- O O 0.5 +0.02V, +0.4V +2.67V, +0.4V 0 M MM M O C CO 0 –0.5 +0.02V, –0.4V +1.35V, –0.4V
7 0 03 04 6- 6- 03
+0.02V, –0.3V +1.35, –0.3V
03
–1.0
07
–0.5
07
–0.5 0 0.5 1.0 1.5 2.0 2.5 3.0 –0.5 0 0.5 1.0 1.5 2.0 2.5 3.0 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V)
Figure 9. Input Common-Mode Voltage vs. Output Voltage, Figure 12. Input Common-Mode Voltage vs. Output Voltage, Single Supply, VS = +2.7 V, G = 1 Single Supply, VS = +2.7 V, G = 100
5 5 +0.02V, +4.3V +2.5V, +4.3V +0.02V, +4.3V V +2.5V, +4.2V REF = +1.35V VREF = +2.5V 4 4 ) ) V V ( ( GE GE A 3 A 3 T +0.02V, +3.0V +4.98V, +3.0V T +0.02V, +3.0V +4.96V, +3.0V OL OL V V E 2 VREF = 0V E V +4.7V, +1.9V 2 REF = 0V +4.7V, +1.9V OD OD -M -M ON 1 +0.02V, +0.8V +4.98V, +0.8V ON 1 M M +0.02V, +0.7V +4.96V, +0.7V OM OM C C 0 0
8 1 03
+2.5V, –0.3.V
04
+0.02V, –0.4V +2.5V, –0.4V
6-
+0.02V, –0.3V
6- 03 03
–1
07
–1
07
–0.5 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 –0.5 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V)
Figure 10. Input Common-Mode Voltage vs. Output Voltage, Figure 13. Input Common-Mode Voltage vs. Output Voltage, Single Supply, VS = +5 V, G = 1 Single Supply, VS = +5 V, G = 100
6 6 0V, +4.3V 0V, +4.2V 4 ) 4 ) V V ( ( GE GE 2 A 2 TA –4.97V, +1.8V +4.96V, +1.8V T –4.96V, +1.7V +4.96V, +1.7V OL OL V V E 0 E D 0 O OD -M -M N O –2 ON –2 M M M –4.97V, –3.0V +4.96V, –0.3V M –4.96V, –3.1V +4.96V, –3.1V O O C C –4 –4 0V, –5.4V
9
0V, –5.3V
2 03 04 6- 6- 03 03
–6
07
–6
07
–6 –4 –2 0 2 4 6 –6 –4 –2 0 2 4 6 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V)
Figure 11. Input Common-Mode Voltage vs. Output Voltage, Figure 14. Input Common-Mode Voltage vs. Output Voltage, Dual Supplies, VS = ±5 V, G = 1 Dual Supplies, VS = ±5 V, G = 100 Rev. D | Page 10 of 28 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ARCHITECTURE GAIN SELECTION REFERENCE TERMINAL INPUT VOLTAGE RANGE Performance Across Temperature Recommendation for Best Performance LAYOUT Common-Mode Rejection Ratio Over Frequency Power Supplies References INPUT BIAS CURRENT RETURN PATH INPUT PROTECTION RADIO FREQUENCY INTERFERENCE (RFI) APPLICATIONS INFORMATION DIFFERENTIAL DRIVE Tips for Best Differential Output Performance PRECISION STRAIN GAGE DRIVING AN ADC OUTLINE DIMENSIONS ORDERING GUIDE
