24 /8 — AD8557. Data Sheet. 0.5. 0.3. S R. IE IF L. 0.1. A (n. OF A. I OS. –0.1. …
Revision
D
PDF / 507 Kb
AD8557. Data Sheet. 0.5. 0.3. S R. IE IF L. 0.1. A (n. OF A. I OS. –0.1. E B M U. –0.3. –0.5. 10 15 20 25 30 35 40 45 50 55 60 65. –50. –25. 100. 125. 150. 175
AD8557Data Sheet350.5300.3S R25IE IF L0.1P20)MA (nOF A15I OSR–0.1E B M U10N–0.350–0.5 2 0510 15 20 25 30 35 40 45 50 55 60 65 0 –50–250255075100125150175 1 0 -01 3- 3 TTEMPERATURE (°C) 01 CVOS (nV/°C) 01 06 06 Figure 10. TCVOS at VSY = 2.7 V, −40°C ≤ TA ≤ +125°C Figure 13. Input Offset Current vs. Temperature 203.0–40°C2.5)A)A18µ ((n+125°C–INT2.0+25°CNTB 5V16CURRE1.5CURRE SUTIA+IB 5VBINP1.0UTAL ITINP14G DI0.5VSY = 5V120–50–250255075100125150175 1 1234 14 01 05 0 3- 3- TEMPERATURE (°C) 01 DIGITAL INPUT VOLTAGE (V) 01 06 06 Figure 11. Input Bias Current at VPOS, VNEG vs. Temperature, Figure 14. Digital Input Current vs. Digital Input Voltage (Pin 4) VSY = 5 V, 2.7 V 1001000+25°C+125°CA) n (A)10n (NTNTCURRE100CURREASP–40°CBIAMUT1CL VINPVSY = 5V0.110012345 13 1234 15 0 05 0 3- 3- COMMON-MODE VOLTAGE (V) 01 VCLAMP VOLTAGE (V) 01 06 06 Figure 12. Input Bias Current at VPOS, VNEG Figure 15. VCLAMP Current over Temperature at VSY = 5 V vs. Common-Mode Voltage, TA = 25°C vs. VCLAMP Voltage Rev. D | Page 8 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION GAIN VALUES OPEN WIRE FAULT DETECTION SHORTED WIRE FAULT DETECTION FLOATING VPOS, VNEG, OR VCLAMP FAULT DETECTION DEVICE PROGRAMMING Digital Interface Initial State Simulation Mode Programming Mode Read Mode Sense Current Programming Procedure Determining Optimal Gain and Offset Codes OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
