AD8557Data Sheet140120CMRR GAIN +28000100CMRR GAIN +4488 × 1CHANNEL 1216.6mV p-pCMRR GAIN +1300=B)INd80A G 1RR (60ISE,CMO E N40G A T L O20V 5 0 02 –50–250255075100125150175 13- 22 0 CH1 10.0mVM 1.00sA CH1 –2.80mV 60 3- 0 TEMPERATURE (°C) 01 06 Figure 22. CMRR vs. Temperature at Different Gains, VSY = 2.7 V Figure 25. Low Frequency Input Voltage Noise 0.1 Hz to 10 Hz, VSY = 2.7 V REF 502µVMARKER 20 000.0Hz5dB/DIVRANGE 12.5mV1.89µV/√Hz70VSY = 5V60 HIGH GAIN +1300 62.28dB 5040) B d30( INLOW GAIN +28 28.9dB20GA100–10–200.11101001k10k 26 0 3- 23 01 START .0 HzSTOP 1 000 000.0HzFREQUENCY (kHz) -0 06 13 RBW 100HzVBW 300HzST 900s 60 0 Figure 23. Input Voltage Noise Density vs. Frequency (0 Hz to 1000 kHz) Figure 26. Closed-Loop Gain vs. Frequency Measured at Output Pin, VSY = 5 V 70VSY = 2.7V60 HIGH GAIN +1300 62.28dB1000508 ×CHANNEL 1215.2mV p-p40= IN)AB d30, G 1(EINLOW GAIN +28 28.9dBIS20GANO E10AG T L0O V–10 4 02 –20 13- CH1 10.0mVM 1.00sA CH1 –2.80mV 60 0.11101001k10k 27 0 0 3- FREQUENCY (kHz) 01 06 Figure 24. Low Frequency Input Voltage Noise, 0.1 Hz to 10 Hz, VSY = 5 V Figure 27. Closed-Loop Gain vs. Frequency Measured at Output Pin, VSY = 2.7 V Rev. D | Page 10 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION GAIN VALUES OPEN WIRE FAULT DETECTION SHORTED WIRE FAULT DETECTION FLOATING VPOS, VNEG, OR VCLAMP FAULT DETECTION DEVICE PROGRAMMING Digital Interface Initial State Simulation Mode Programming Mode Read Mode Sense Current Programming Procedure Determining Optimal Gain and Offset Codes OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
