Datasheet AD1835A (Analog Devices) - 8
Description | 2 ADC, 8 DAC, 96 kHz, 24-Bit Sigma Delta Codec |
Pages / Page | 24 / 8 — AD1835A–Typical Performance Characteristics. –50. –10. –100. –15. … |
Revision | A |
File Format / Size | PDF / 282 Kb |
AD1835A–Typical Performance Characteristics. –50. –10. –100. –15. MAGNITUDE – dB. –20. –150. –25. –30. FREQUENCY – Normalized to fS
AD1835A–Typical Performance Characteristics 0 5 0 –50 –5 –10 –100 –15 MAGNITUDE – dB MAGNITUDE – dB –20 –150 –25 –30 0 5 10 15 0 5 10 15 20 FREQUENCY – Normalized to fS FREQUENCY – Hz
TPC 1. ADC Composite Filter Response TPC 4. ADC High-Pass Filter Response, fS = 96 kHz
5 0 0 –5 –50 –10 –15 GNITUDE – dB MAGNITUDE – dB MA –100 –20 –25 –30 –150 0 5 10 15 20 0 50 100 150 200 FREQUENCY – Hz FREQUENCY – kHz
TPC 2. ADC High-Pass Filter Response, fS = 48 kHz TPC 5. DAC Composite Filter Response, fS = 48 kHz
0 0 –50 –50 GNITUDE – dB MAGNITUDE – dB –100 MA –100 –150 0 0.5 1.0 1.5 2.0 –150 0 50 100 150 200 FREQUENCY – Normalized to fS FREQUENCY – kHz
TPC 3. ADC Composite Filter Response TPC 6. DAC Composite Filter Response, fS = 96 kHz (Pass-Band Section) –8– REV. A Document Outline FEATURES APPLICATIONS PRODUCT OVERVIEW FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS TEMPERATURE RANGE ORDERING GUIDE PIN CONFIGURATION PIN FUNCTION DESCRIPTIONS Typical Performance Characteristics DEFINITIONS Dynamic Range Signal-to-(Total Harmonic Distortion + Noise)[S/(THD + N)] Pass Band Pass-Band Ripple Stop Band Gain Error Interchannel Gain Mismatch Gain Drift Crosstalk (EIAJ Method) Power Supply Rejection Group Delay Group Delay Variation GLOSSARY FUNCTIONAL OVERVIEW ADCs DACs DAC and ADC Coding AD1835A CLOCKING SCHEME Selecting DAC Sampling Rate Selecting an ADC Sample Rate RESET and Power-Down Power Supply and Voltage Reference Serial Control Port Serial Data Ports—Data Format Packed Modes Auxiliary (TDM) Mode CONTROL/STATUS REGISTERS DAC Control Registers Sample Rate Power-Down/Reset DAC Data-Word Width DAC Data Format De-emphasis Mute DAC Stereo Replicate DAC Volume Control ADC Control Registers ADC Peak Level Sample Rate ADC Power-Down High-Pass Filter ADC Data-Word Width ADC Data Format Master/Slave Auxiliary Mode ADC Peak Readback CASCADE MODE Dual AD1835A Cascade OUTLINE DIMENSIONS Revision History
