Datasheet 1N4150 (Vishay) - 2
ManufacturerVishay
DescriptionSmall Signal Fast Switching Diodes
Pages / Page3 / 2 — 1N4150. ELECTRICAL CHARACTERISTICS. PARAMETER. TEST CONDITION. SYMBOL. …
File Format / SizePDF / 76 Kb
1N4150. ELECTRICAL CHARACTERISTICS. PARAMETER. TEST CONDITION. SYMBOL. MIN. TYP. MAX. UNIT. TYPICAL CHARACTERISTICS. PACKAGE DIMENSIONS
1N4150 ELECTRICAL CHARACTERISTICS PARAMETER TEST CONDITION SYMBOL MIN TYP MAX UNIT TYPICAL CHARACTERISTICS PACKAGE DIMENSIONS
1N4150
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
IF = 1 mA VF 0.540 0.620 V IF = 10 mA VF 0.660 0.740 V Forward voltage IF = 50 mA VF 0.760 0.860 V IF = 100 mA VF 0.820 0.920 V IF = 200 mA VF 0.870 1 V VR = 50 V IR 100 nA Reverse current VR = 50 V, Tj = 150 °C IR 100 μA V Diode capacitance R = 0 V, f = 1 MHz, C V D 2.5 pF HF = 50 mV I Reverse recovery time F = IR = (10 to 100) mA, iR = 0.1 x IR, RL = 100 Ω trr 4 ns
(Tamb = 25 °C, unless otherwise specified) 100 1000 Scattering Limit 10 100 Scattering Limit 1 10 - Reverse Current (µA) 0.1 1 I R - Forward Current (mA) I F V = 50 V R T = 25 °C J 0.01 0.1 0 40 80 120 160 200 0 0.4 0.8 1.2 1.6 2.0 94 9100 TJ - Junction Temperature (°C) 94 9162 VF - Forward Voltage (V) Fig. 1 - Reverse Current vs. Junction Temperature Fig. 2 - Forward Current vs. Forward Voltage
PACKAGE DIMENSIONS
in millimeters (inches):
DO-35 (DO-204AH)
Cathode Identification ] ] 24] 7 0 .0 .015] 6 5 [0 .0 .0 [0 26 min. [1.024] 3.9 max. [0.154] 26 min. [1.024] 0 0 x. [ [ a in. 7 3 1. 1. 3.1 min. [0.120] 6 m 4 m 0. 0. Ø Ø Rev. 6 - Date: 19. December 2011 Document no.: SB-V-3906.04-031(4) 94 9366 Rev. 1.9, 06-Jul-17
2
Document Number: 85522 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
