Datasheet FDS6890A (ON Semiconductor) - 2
ManufacturerON Semiconductor
DescriptionDual N-Channel 2.5V Specified PowerTrenchTM MOSFET
Pages / Page5 / 2 — FDS6890A. Electrical Characteristics. Symbol. Parameter. Test Conditions. …
Revision3
File Format / SizePDF / 199 Kb
FDS6890A. Electrical Characteristics. Symbol. Parameter. Test Conditions. Min. Typ Max Units. Off Characteristics. On Characteristics
FDS6890A Electrical Characteristics Symbol Parameter Test Conditions Min Typ Max Units Off Characteristics On Characteristics
T = 25 C unless otherwise noted A
BVDSS Drain-Source Breakdown Voltage VGS = 0 V, ID = 250 µA 20 V ∆BVDSS Breakdown Voltage Temperature ID = 250 µA, Referenced to 25°C 14 mV/°C ∆T Coefficient J IDSS Zero Gate Voltage Drain Current VDS = 16 V, VGS = 0 V 1 µA IGSSF Gate-Body Leakage Current, VGS = 8 V, VDS = 0 V 100 nA Forward IGSSR Gate-Body Leakage Current, VGS = -8 V, VDS = 0 V -100 nA Reverse
On Characteristics
(Note 2) VGS(th) Gate Threshold Voltage VDS = VGS, ID = 250 µA 0.5 0.8 1.5 V ∆VGS(th) Gate Threshold Voltage ID = 250 µA, Referenced to 25°C -3.5 mV/°C ∆T Temperature Coefficient J RDS(on) Static Drain-Source VGS = 4.5 V, ID =7.5 A 0.013 0.018 Ω On-Resistance VGS = 4.5 V, ID =7.5 A, TJ =125°C 0.021 0.034 VGS = 2.5 V, ID =6.5 A 0.016 0.022 ID(on) On-State Drain Current VGS = 10 V, VDS = 5 V 20 A gFS Forward Transconductance VDS = 5 V, ID = 7.5 A 35 S
Dynamic Characteristics
Ciss Input Capacitance VDS = 10 V, VGS = 0 V, 2130 pF C f = 1.0 MHz oss Output Capacitance 545 pF Crss Reverse Transfer Capacitance 270 pF
Switching Characteristics
(Note 2) td(on) Turn-On Delay Time VDD = 10 V, ID = 1 A, 13 24 ns t VGS = 4.5 V, RGEN = 6 Ω r Turn-On Rise Time 26 42 ns td(off) Turn-Off Delay Time 65 90 ns tf Turn-Off Fall Time 23 37 ns Qg Total Gate Charge VDS = 10 V, ID = 7.5 A, 23 32 nC Q VGS = 4.5 V, gs Gate-Source Charge 3.2 nC Qgd Gate-Drain Charge 4.4 nC
Drain-Source Diode Characteristics and Maximum Ratings
IS Maximum Continuous Drain-Source Diode Forward Current 1.3 A VSD Drain-Source Diode Forward VGS = 0 V, IS = 1.3 A (Note 2) 0.65 1.2 V Voltage
Notes: 1.
Rθ is the sum of the junction-to-case and case-to-ambient thermal resistance where the case thermal reference is defined as the solder mounting JA surface of the drain pins. Rθ is guaranteed by design while R is determined by the user's board design. JC θCA a) 78° C/W when b) 125° C/W when c) 135° C/W when mounted on a 0.5 in2 mounted on a 0.02 in2 mounted on a minimum pad. pad of 2 oz. copper. pad of 2 oz. copper. Scale 1 : 1 on letter size paper www.onsemi.com 2
