Datasheet MAX4230, MAX4231, MAX4232, MAX4233, MAX4234 (Maxim) - 7
Manufacturer | Maxim |
Description | High-Output-Drive, 10MHz, 10V/µs, Rail-to-Rail I/O Op Amps with Shutdown in SC70 |
Pages / Page | 15 / 7 — Typical Operating Characteristics (continued). SMALL-SIGNAL TRANSIENT. … |
File Format / Size | PDF / 1.9 Mb |
Typical Operating Characteristics (continued). SMALL-SIGNAL TRANSIENT. LARGE-SIGNAL TRANSIENT. RESPONSE (NONINVERTING)
MAX4230–MAX4234 High-Output-Drive, 10MHz, 10V/μs, Rail-to-Rail I/O Op Amps with Shutdown in SC70
(VDD = 2.7V, VSS = 0V, VCM = VDD/2, VOUT = VDD/2, RL = ∞, connected to VDD/2, VSHDN = VDD, TA = +25°C, unless otherwise noted.)
SMALL-SIGNAL TRANSIENT SMALL-SIGNAL TRANSIENT LARGE-SIGNAL TRANSIENT RESPONSE (NONINVERTING) RESPONSE (INVERTING) RESPONSE (NONINVERTING)
MAX4230/34 toc16 MAX4230/34 toc17 MAX4230/34 toc18 IN IN IN 50mV/div 50mV/div 1V/div OUT OUT OUT 400ns/div 400ns/div 400ns/div
LARGE-SIGNAL TRANSIENT OUTPUT CURRENT vs. OUTPUT VOLTAGE OUTPUT CURRENT vs. OUTPUT VOLTAGE RESPONSE (INVERTING) (SOURCING, VDD = 2.7V) (SINKING, VDD = 2.7V)
MAX4230/34 toc19 80 0 VDIFF = 100mV VDIFF = 100mV IN 70 -10 60 MAX4230/34 toc20 -20 MAX4230/34 toc21 50 -30 1V/div 40 -40 30 -50 OUT OUTPUT CURRENT (mA) 20 OUTPUT CURRENT (mA) -60 10 -70 0 -80 400ns/div 1.0 1.2 1.4 1.6 1.8 2.0 2.2 2.4 2.6 2.8 3.0 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V)
OUTPUT CURRENT vs. OUTPUT VOLTAGE OUTPUT CURRENT vs. OUTPUT VOLTAGE INPUT VOLTAGE NOISE (SOURCING, VDD = 5.0V) (SINKING, VDD = 5.0V) vs. FREQUENCY
250 0 200 VDIFF = 100mV VDIFF = 100mV 100 200 -50 √Hz) MAX4230/34 toc22 MAX4230/34 toc23 MAX4230/34 toc24 150 -100 100 -150 OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) 50 -200 INPUT VOLTAGE NOISE (nV/ 0 -250 10 2.0 2.5 3.0 3.5 4.0 4.5 5.0 0 0.5 1.0 1.5 2.0 2.5 3.0 100 1k 10k 100k OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) FREQUENCY (Hz) www.maximintegrated.com Maxim Integrated │ 7
