Datasheet MAX4230, MAX4231, MAX4232, MAX4233, MAX4234 (Maxim) - 6
Manufacturer | Maxim |
Description | High-Output-Drive, 10MHz, 10V/µs, Rail-to-Rail I/O Op Amps with Shutdown in SC70 |
Pages / Page | 15 / 6 — Typical Operating Characteristics (continued). SUPPLY CURRENT PER … |
File Format / Size | PDF / 1.9 Mb |
Typical Operating Characteristics (continued). SUPPLY CURRENT PER AMPLIFIER. INPUT OFFSET VOLTAGE. OUTPUT SWING HIGH
MAX4230–MAX4234 High-Output-Drive, 10MHz, 10V/μs, Rail-to-Rail I/O Op Amps with Shutdown in SC70
(VDD = 2.7V, VSS = 0V, VCM = VDD/2, VOUT = VDD/2, RL = ∞, connected to VDD/2, VSHDN = VDD, TA = +25°C, unless otherwise noted.)
SUPPLY CURRENT PER AMPLIFIER INPUT OFFSET VOLTAGE OUTPUT SWING HIGH vs. SUPPLY VOLTAGE vs. TEMPERATURE vs. TEMPERATURE
2.0 2 1.8 100 VDD = 5.0V RL = 200Ω 1.6 VDD = 2.7V MAX4230 toc07 MAX4230 toc08 1 MAX4230/34 toc09 1.4 80 1.2 (mV) VDD = 2.7V 60 RL = 200Ω 1.0 (mV) 0 VDD = 5.0V OUT V OS - V 0.8 V DD 40 0.6 SUPPLY CURRENT (mA) -1 0.4 20 0.2 0 -2 0 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 -40 -20 0 20 40 60 80 100 120 -40 -20 0 20 40 60 80 100 120 SUPPLY VOLTAGE (V) TEMPERATURE (°C) TEMPERATURE (°C)
OUTPUT SWING LOW INPUT OFFSET VOLTAGE SUPPLY CURRENT PER AMPLIFIER vs. TEMPERATURE vs. COMMON-MODE VOLTAGE vs. COMMON-MODE VOLTAGE
140 1.0 1.2 120 VDD = 5.0V 0.5 MAX4230/3 toc10 R 1.0 L = 200Ω MAX4230/3 toc11 MAX4230/3 toc12 100 0 (mV) 80 0.8 SS - V -0.5 60 V V OUT DD = 2.7V 0.6 RL = 200Ω -1.0 40 SUPPLY CURRENT (mA) INPUT OFFSET VOLTAGE (mV) 0.4 20 -1.5 VDD = 2.7V 0 -2.0 0.2 -40 -20 0 20 40 60 80 100 120 0 0.5 1.0 1.5 2.0 2.5 0 0.5 1.0 1.5 2.0 2.5 TEMPERATURE (°C) COMMON-MODE VOLTAGE (V) COMMON-MODE VOLTAGE (V)
SUPPLY CURRENT PER AMPLIFIER TOTAL HARMONIC DISTORTION TOTAL HARMONIC DISTORTION PLUS NOISE vs. COMMON-MODE VOLTAGE PLUS NOISE vs. FREQUENCY vs. PEAK-TO-PEAK OUTPUT VOLTAGE
1.4 0.45 10 VOUT = 2VP-P f = 10kHz 0.40 500kHz LOWPASS FILTER VDD = 5V RL = 100k 1.2 0.35 RL = 2k MAX4230/34 toc13 MAX4230/34 toc14 MAX4230/34 toc15 1 RL = 250 1.0 0.30 RL = 25 0.25 0.8 0.20 0.1 THD+N (%) THD+N (%) 0.6 0.15 SUPPLY CURRENT (mA) VDD = 5.0V 0.10 RL = 32 0.4 0.001 0.05 R 0.2 0 L = 10k 0.0001 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 10 100 1k 10k 100k 4.0 4.2 4.4 4.6 4.8 5.0 COMMON-MODE VOLTAGE (V) FREQUENCY (Hz) PEAK-TO-PEAK OUTPUT VOLTAGE (V) www.maximintegrated.com Maxim Integrated │ 6
