Datasheet PS508, PS509 (Diodes) - 5
ManufacturerDiodes
DescriptionPrecision 8-Channels, Differential 4-Channels, 36V Analog Multiplexers
Pages / Page15 / 5 — PS508/PS509. Electrical Characteristics: Dual Supply. Symbol. Parameters. …
PS508/PS509. Electrical Characteristics: Dual Supply. Symbol. Parameters. Conditions. Min. Typ. Max. Units
PS508/PS509 Electrical Characteristics: Dual Supply Symbol Parameters Conditions Min Typ Max Units
A product Line of Diodes Incorporated
At T = 25°C, V = 15V, and V = –15V (unless otherwise noted) A DD SS
Symbol Parameters Conditions Min. Typ. Max. Units
Analog Switch Analog signal range T = –40°C to +125°C V V V A SS DD V = 0V, I = 1mA 125 170 Ω S CH 145 200 Ω R On-resistance ON V = ±10V, I = 1mA T = –40°C to +85°C 230 Ω S CH A T = –40°C to +125°C 250 Ω A On-resistance mis- 2.4 6 Ω ∆R match between chan- V = ±10V, I = 1mA T = –40°C to +85°C 9 Ω ON S CH A nels T = –40°C to +125°C 11 Ω A 22 45 Ω R On-resistance flatness V = 10V, 0V, –10V T = –40°C to +85°C 53 Ω FLAT S A T = –40°C to +125°C 58 Ω A On-resistance drift V = 0V 0.52 %/oC S -1 0.03 1 nA I Input leakage current Switch state is off, V = S T = –40°C to +85°C -10 10 nA S(OFF) ±10V, V = ±10V(1) A D T = –40°C to +125°C -25 25 nA A -1 0.22 1 nA I Output off leakage Switch state is off, V = S T = –40°C to +85°C -10 10 nA D(OFF) current ±10V, V = ±10V(1) A D T = –40°C to +125°C -50 50 nA A -1 0.25 1 nA I Output on leakage Switch state is on, V = D T = –40°C to +85°C -10 10 nA D(ON) current ±10V, V = floating A S T = –40°C to +125°C -50 50 nA A Logic Input V High-level input voltage 2.0 V IH V Low-level input voltage 0.8 V IL ID Input current 0.15 μA Switch Dynamics(2) 126 210 ns t Enable turn-on time V = ±10V, R = 300Ω, S L T = –40°C to +85°C 210 ns ON C = 35pF A L T = –40°C to +125°C 210 ns A 125 191 ns t Enable turn-off time V = ±10V, R = 300Ω, S L T = –40°C to +85°C 191 ns OFF C = 35pF A L T = –40°C to +125°C 191 ns A PS508/PS509 Document Number DS41784 Rev 2-2 5 www.diodes.com June 2020 Diodes Incorporated
