Datasheet AOZ8S212UD4 (Alpha & Omega) - 6
ManufacturerAlpha & Omega
Description4-Channel Ultra-Low Capacitance TVS Diode Array
Pages / Page6 / 6 — AOZ8S212UD4. LEGAL DISCLAIMER. LIFE SUPPORT POLICY. www.aosmd.com
File Format / SizePDF / 532 Kb
AOZ8S212UD4 LEGAL DISCLAIMER LIFE SUPPORT POLICY www.aosmd.com
Applications or uses as critical components in life support devices or systems are not authorized. AOS does not assume any liability arising out of such applications or uses of its products. AOS reserves the right to make changes to product specifications without notice. It is the responsibility of the customer to evaluate suitability of the product for their intended application. Customer shall comply with applicable legal requirements, including all applicable export control rules, regulations and limitations. AOS' products are provided subject to AOS' terms and conditions of sale which are set forth at: http://www.aosmd.com/terms_and_conditions_of_sale
LIFE SUPPORT POLICY
ALPHA AND OMEGA SEMICONDUCTOR PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS. As used herein: 1. Life support devices or systems are devices or 2. A critical component in any component of a life systems which, (a) are intended for surgical implant into support, device, or system whose failure to perform can the body or (b) support or sustain life, and (c) whose be reasonably expected to cause the failure of the life failure to perform when properly used in accordance support device or system, or to affect its safety or with instructions for use provided in the labeling, can be effectiveness. reasonably expected to result in a significant injury of the user. Rev. 1.0 July 2020
www.aosmd.com
Page 6 of 6
