link to page 9 link to page 9 LTC6226/LTC6227 ELECTRICAL CHARACTERISTICS (VThe l denotes the specifications which applyS = 5V, 0V)over the full operating temperature range, otherwise specifications are at TA = 25°C. VS = 5V, 0V,VCM = VOUT = 2.5V, VSHDN = floatingunless otherwise noted.SYMBOL PARAMETERCONDITIONSMINTYPMAXUNITS VCMR Input Common Mode Range (Note 10) l V– – 0.1 V+ – 1.2 V PSRR+ Positive Power Supply Rejection Ratio V– = –1V, V+ = 1.8V to 10.75V 100 115 dB l 95 dB PSRR– Negative Power Supply Rejection Ratio V+ = 1.5V, V– = –1.3V to –10.25V 103 127 dB l 100 dB Supply Voltage Range (V+ – V–) (Note 7) l 2.8 11.75 V VOL Output Swing Low (VOUT – VEE) No Load 16 21 mV l 23 mV ISINK = 5mA 90 110 mV l 155 mV ISINK = 15mA 220 270 mV l 370 mV VOH Output Swing High (VCC – VOUT) No Load 11 15 mV l 20 mV ISINK = 5mA 150 180 mV l 200 mV ISOURCE = 15mA 331 500 mV l 650 mV ISC Output Short-Circuit Current Sourcing –52 –34 mA l –30 mA Sinking 42 57 mA l 30 mA IS Supply Current per Channel 5.8 6.3 mA l 7.6 mA ISD Disable Supply Current Per Amplifier, Amplifier VSHDN = V+ – 2.65V 245 310 μA Off l 330 μA VL_SHDN SHDN Pin Input Voltage Low, Disable Amplifier l V+ – 2.65 V VH_SHDN SHDN Pin Input Voltage High, Enable Amplifier l V+ – 1.6 V IL_SHDN SHDN Pin Input Current, Disable Amplifier VSHDN = V+ – 2.65V l –10 –2.9 10 μA IH_SHDN SHDN Pin Input Current, Enable Amplifier VSHDN = V+ – 1.6V l –10 –0.3 10 μA IOSD Output Leakage Current in Shutdown 100 nA BW –3dB Closed Loop Bandwidth AV = 1, RL = 1kΩ to Half Supply 490 MHz GBW Gain-Bandwidth Product f = 5MHz, RL = 1kΩ to Half Supply 350 430 MHz l 290 MHz tON Turn-On Time VSHDN = V+ – 2.65V to V+ – 1.6V 2100 ns tOFF Turn-Off Time VSHDN = V+ – 1.6V to V+ – 2.65V 800 ns tS_0.1 Settling Time to 0.1% AV = 1, 2V Output Step, RL = 1kΩ 59 ns Rev 0 6 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics (VS = ±5V) Electrical Characteristics (VS = 5V, 0V) Electrical Characteristics (VS = 3V, 0V) Typical Performance Characteristics Pin Functions Applications Information Typical Applications Package Description Typical Application Related Parts
