Datasheet ADA4099-1 (Analog Devices) - 10
Description50 V, 8 MHz, 1.5 mA, Robust, Over-The-Top Precision Op Amp
Pages / Page26 / 10 — ADA4099-1. Preliminary Technical Data. VSY = ±25V. SY = ±25V. CM = 0V. …
RevisionPrA
File Format / SizePDF / 577 Kb
ADA4099-1. Preliminary Technical Data. VSY = ±25V. SY = ±25V. CM = 0V. 1084 UNITS. CM = MIDSUPPLY. 10 REPRESENTATIVE UNITS. V µ. E G. OF U
ADA4099-1 Preliminary Technical Data VSY = ±25V SY = ±25V CM = 0V 1084 UNITS CM = MIDSUPPLY 10 REPRESENTATIVE UNITS V µ E G OF U
ADA4099-1 Preliminary Technical Data 16 75 VSY = ±25V V 14 V SY = ±25V CM = 0V V 1084 UNITS 50 CM = MIDSUPPLY ) 10 REPRESENTATIVE UNITS 12 (% ) S V µ IT ( 25 N 10 E G OF U 8 E 0 OLTA G V TA T N 6 E E C –25 R OFFS E 4 P –50 2 0 –75 –25 –20 –15 –10 –5 0 5 10 15 20 25
012
–60 –30 0 30 60 90 120 150
015 72- 72-
OFFSET VOLTAGE (µV)
221
TEMPERATURE (°C)
221 Figure 11. Typical Distribution of Input Offset Voltage with VSY = ±25 V Figure 14. Offset Voltage vs. Temperature with VSY = ±25 V
75 15 VSY = 5V V V ) SY = 5V CM = MIDSUPPLY A V 50 10 REPRESENTATIVE UNITS 10 CM = MIDSUPPLY (n 10 REPRESENTATIVE UNITS ) NT (µV 25 RRE 5 E G CU A T AS 0 BI 0 VOL T UT E P S F –25 IN Y –5 OF L P P U –50 –10 IDS M –75 –15 –60 –30 0 30 60 90 120 150
013
–50 –25 0 25 50 75 100 125
016 72- 72-
TEMPERATURE (°C)
221
TEMPERATURE (°C)
221 Figure 12. Offset Voltage vs. Temperature with VSY = 5 V Figure 15. Midsupply Input Bias Current vs. Temperature with VSY = 5 V
75 15 VSY = ±15V A) VSY = ±15V 50 VCM = MIDSUPPLY 10 VCM = MIDSUPPLY 10 REPRESENTATIVE UNITS (n 10 REPRESENTATIVE UNITS NT ) µV ( 25 RRE 5 GE CU AS 0 OLTA BI 0 V T T U E –25 INP Y –5 L OFFS P UP –50 S –10 ID M –75 –15 –60 –30 0 30 60 90 120 150
014
017 72- 72-
TEMPERATURE (°C)
221
TEMPERATURE (°C)
221 Figure 13. Offset Voltage vs. Temperature with VSY = ±15 V Figure 16. Midsupply Input Bias Current vs. Temperature with VSY = ±15 V Rev. PrA | Page 10 of 26 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TYPICAL APPLICATION CIRCUIT TABLE OF CONTENTS SPECIFICATIONS 5 V SUPPLY ±15 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT PROTECTION OVER-THE-TOP OPERATION CONSIDERATIONS OUTPUT SHUTDOWN PIN (SHDN) APPLICATIONS INFORMATION LARGE RESISTOR GAIN OPERATION RECOMMENDED VALUES FOR VARIOUS GAINS NOISE DISTORTION POWER DISSIPATION AND THERMAL SHUTDOWN CIRCUIT LAYOUT CONSIDERATIONS POWER SUPPLY BYPASSING GROUNDING ESD PROTECTION WHEN POWERED RELATED PRODUCTS TYPICAL APPLICATIONS OUTLINE DIMENSIONS
