DatasheetsDatasheet ADA4897-2-KGD (Analog Devices)
Description | 1 nV/√Hz, Low Power Operational Amplifier |
Pages / Page | 10 / 1 — 1 nV/√Hz, Low Power, Rail-to-Rail. Output Amplifier. Known Good Die. … |
Revision | C |
File Format / Size | PDF / 238 Kb |
1 nV/√Hz, Low Power, Rail-to-Rail. Output Amplifier. Known Good Die. ADA4897-2-KGD. FEATURES. GENERAL DESCRIPTION
1 nV/√Hz, Low Power, Rail-to-Rail Output Amplifier Known Good Die ADA4897-2-KGD FEATURES GENERAL DESCRIPTION Low wideband noise
The ADA4897-2-KGD1 is a unity-gain stable, low noise, rail-to-
1 nV/√Hz
rail output, high speed voltage feedback amplifier that has a
2.8 pA/√Hz
quiescent current of 3 mA. With a 1/f noise of 2.4 nV/√Hz at
Low 1/f noise: 2.4 nV/√Hz at 10 Hz
10 Hz and a spurious-free dynamic range of −80 dBc at 2 MHz,
Low distortion: −115 dBc at 100 kHz, VOUT = 2 V p-p
the ADA4897-2-KGD is an ideal solution in a variety of
Low input offset voltage: 500 μV maximum
applications, including ultrasound, low noise preamplifiers, and
High speed
drivers of high performance analog-to-digital converters (ADCs).
−3 dB bandwidth: 230 MHz (G = +1)
The Analog Devices, Inc., proprietary next generation silicon
Slew rate: 120 V/μs
germanium (SiGe) bipolar process and innovative architecture
Settling time to 0.1%: 45 ns
enable such high performance amplifiers.
Rail-to-rail output
The ADA4897-2-KGD has a 230 MHz bandwidth, a 120 V/μs
Wide supply range: 3 V to 10 V
slew rate, and settles to 0.1% in 45 ns. With a wide supply
Disable feature
voltage range of 3 V to 10 V, the ADA4897-2-KGD is ideal for
Known good die (KGD): these die are fully guaranteed to
systems that require high dynamic range, precision, low power,
data sheet specifications
and high speed.
The ADA4897-2-KGD is rated to work over the industrial
Low noise preamplifiers
temperature range of −40°C to +125°C.
Ultrasound amplifiers
Additional application and technical information can be found
Phase-locked loop (PLL) filters
in the ADA4897-2 data sheet.
High performance ADC drivers Digital-to-analog converter (DAC) buffers
1 Protected by U.S. Patent Numbers 6,486,737B1 and 6,518,842B1.
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2014–2019 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Revision History Specifications ±5 V Supply +5 V Supply +3 V Supply Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Outline Dimensions Die Specifications and Assembly Recommendations Ordering Guide
