Datasheet ADA4817-1, ADA4817-2 (Analog Devices) - 6
DescriptionDual, Low Noise, 1 GHz FastFET Op Amplifier
Pages / Page31 / 6 — ADA4817-1/. ADA4817-2. Data Sheet. Parameter. Test Conditions/Comments. …
RevisionG
File Format / SizePDF / 632 Kb
ADA4817-1/. ADA4817-2. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit. 5 V OPERATION. Table 2. Parameter
ADA4817-1/ ADA4817-2 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit 5 V OPERATION Table 2 Parameter
Output Voltage Swing High RL = 100 Ω +VS − 1.5 +VS − 1.3 V RL = 100 Ω, TMIN to TMAX +VS − 1.65 V RL = 1 kΩ +VS − 1.1 +VS − 1 V RL = 1 kΩ, TMIN to TMAX +VS − 1.4 V Low RL = 100 Ω −VS + 1.4 −VS + 1.5 V RL = 100 Ω, TMIN to TMAX −VS + 1.65 V RL = 1 kΩ −VS + 1 −VS + 1.1 V RL = 1 kΩ, TMIN to TMAX −VS + 1.2 V Linear Output Current 1% output error 40 mA Short-Circuit Current Sinking 100 mA Sourcing 170 mA POWER-DOWN PD Pin Voltage Enabled, TMIN to TMAX >+VS − 0.9 V Powered down, TMIN to TMAX <+VS − 3.5 V Turn On Time 0.3 µs Turn Off Time 1 µs Input Leakage Current PD = +VS 0.3 3 µA PD = −VS 34 61 µA POWER SUPPLY Operating Range 5 10 V Quiescent Current per Amplifier 19 21 mA Powered Down Quiescent Current 1.5 3 mA Positive Power Supply Rejection +VS = 4.5 V to 5.5 V, −VS = −5 V −67 −72 dB Negative Power Supply Rejection +VS = 5 V, −VS = −4.5 V to −5.5 V −67 −72 dB
5 V OPERATION
TA = 25°C, +VS = 3 V, −VS = −2 V, G = 1, RF = 348 Ω for G > 1, RL = 100 Ω to ground, unless otherwise noted.
Table 2. Parameter Test Conditions/Comments Min Typ Max Unit
DYNAMIC PERFORMANCE –3 dB Bandwidth VOUT = 0.1 V p-p 500 MHz VOUT = 1 V p-p 160 MHz VOUT = 0.1 V p-p, G = 2 280 MHz Full Power Bandwidth VIN = 1 V p-p, G = 2 95 MHz 0.1 dB Flatness VOUT = 1 V p-p, G = 2 32 MHz Slew Rate VOUT = 2 V step 320 V/µs Settling Time to 0.1% VOUT = 1 V step, G = 2 11 Ns NOISE/HARMONIC PERFORMANCE Harmonic Distortion f = 1 MHz VOUT = 1 V p-p, RL = 1 kΩ dBc HD2 −87 dBc HD3 −88 f = 10 MHz VOUT = 1 V p-p, RL = 1 kΩ HD2 −68 dBc HD3 −66 dBc f = 50 MHz VOUT = 1 V p-p, RL = 1 kΩ HD2 −57 dBc HD3 −55 dBc Rev. G | Page 6 of 31 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS ±5 V OPERATION 5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM SAFE POWER DISSIPATION ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION CLOSED-LOOP FREQUENCY RESPONSE NONINVERTING CLOSED-LOOP FREQUENCY RESPONSE INVERTING CLOSED-LOOP FREQUENCY RESPONSE WIDEBAND OPERATION DRIVING CAPACITIVE LOADS THERMAL CONSIDERATIONS POWER-DOWN OPERATION CAPACITIVE FEEDBACK HIGHER FREQUENCY ATTENUATION LAYOUT, GROUNDING, AND BYPASSING CONSIDERATIONS SIGNAL ROUTING POWER SUPPLY BYPASSING GROUNDING EXPOSED PAD LEAKAGE CURRENTS INPUT CAPACITANCE INPUT-TO-INPUT/OUTPUT COUPLING APPLICATIONS INFORMATION LOW DISTORTION PINOUT WIDEBAND PHOTODIODE PREAMP HIGH SPEED JFET INPUT INSTRUMENTATION AMPLIFIER ACTIVE LOW-PASS FILTER (LPF) OUTLINE DIMENSIONS ORDERING GUIDE
