Datasheet AD8397 (Analog Devices) - 10
Description | Rail-to-Rail, High Output Current Amplifier |
Pages / Page | 16 / 10 — AD8397. Data Sheet. –40. –10. –50. –20. –30. –60. –70. –80. –90. SECOND. … |
Revision | B |
File Format / Size | PDF / 307 Kb |
AD8397. Data Sheet. –40. –10. –50. –20. –30. –60. –70. –80. –90. SECOND. DISTORTION (. HARMONIC. –100. THIRD. –110. –120. 0.01. 0.1. FREQUENCY (MHz)
AD8397 Data Sheet 0 –40 –10 –50 –20 –30 –60 ) –40 ) Bc Bc –70 d –50 d –60 –80 –70 –90 –80 SECOND DISTORTION ( DISTORTION ( HARMONIC –90 SECOND –100 HARMONIC –100 THIRD –110 HARMONIC –110 THIRD
023 026
HARMONIC –120
05069-
–120
05069-
0.01 0.1 1 10 0 1 2 3 4 5 6 7 8 9 10 FREQUENCY (MHz) OUTPUT VOLTAGE (V p-p)
Figure 17. Distortion vs. Frequency Figure 20. Distortion vs. Output Voltage @ 100 kHz, (VS = ±5 V, VO = 2 V p-p, G = +2, RL = 25 Ω) (VS = ±5 V, G = +2, RL = 25 Ω)
–40 –40 –50 –50 –60 –60 ) ) Bc –70 Bc –70 d d –80 –80 SECOND SECOND HARMONIC HARMONIC –90 –90 DISTORTION ( DISTORTION ( –100 –100 THIRD THIRD HARMONIC HARMONIC –110 –110
024 027
–120
05069-
–120
05069-
0 0.25 0.50 0.75 1.00 1.25 1.50 1.75 2.00 2.25 2.50 2.75 0 2 4 6 8 10 12 14 16 18 20 22 24 OUTPUT VOLTAGE (V p-p) OUTPUT VOLTAGE (V p-p)
Figure 18. Distortion vs. Output Voltage @ 100 kHz, Figure 21. Distortion vs. Output Voltage @ 100 kHz, (VS = ±1.5 V, G = +2, RL = 25 Ω) (VS = ±12 V, G = +5, RL = 50 Ω)
–40 –50 –60 ) Bc –70 d –80 –90 SECOND DISTORTION ( HARMONIC –100 –110
025
THIRD HARMONIC –120
05069-
0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 OUTPUT VOLTAGE (V p-p)
Figure 19. Distortion vs. Output Voltage @ 100 kHz, (VS = ±2.5 V, G = +2, RL = 25 Ω) Rev. B | Page 10 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION POWER SUPPLY AND DECOUPLING LAYOUT CONSIDERATIONS UNITY-GAIN OUTPUT SWING CAPACITIVE LOAD DRIVE OUTLINE DIMENSIONS ORDERING GUIDE
