20 /7 — Data Sheet. AD8651/AD8652. 2.50. VS = ±2.5V. VS = 5V IL = 250µA. 2.00. …
Revision
D
PDF / 468 Kb
Data Sheet. AD8651/AD8652. 2.50. VS = ±2.5V. VS = 5V IL = 250µA. 2.00. 1.50. G LO IN. URRE. C Y. 1.00. 0.50. –50. 100. 150. TEMPERATURE (°C). 500. 400. 300
Data SheetAD8651/AD8652122.50VS = ±2.5VVS = 5V IL = 250µA112.00))VA10(m(mW1.50NT9G LO INURREWC YS1.00LTP8UUPTPSOU0.50760 11 14 –50050100150 -0 –50050100150 0 1- 01 TEMPERATURE (°C) 30 33 TEMPERATURE (°C) 0 03 Figure 11. Supply Current vs. Temperature Figure 14. Output Voltage Swing Low vs. Temperature 500100VS = ±2.5VVS = ±2.5V40080V)30060) (mB)TVOHdOUVRR (–200CM40SY(VVOL1002000 12 15 020406080100 0 101001k10k100k1M10M -0 1- 01 CURRENT LOAD (mA) 330 FREQUENCY (Hz) 33 0 0 Figure 12. Output Voltage to Supply Rail vs. Load Current Figure 15. CMRR vs. Frequency 4.997110VS = 5VVS = ±2.5VIL = 250µA4.996)105V 4.995(IGH 4.994B)G HdIN100W 4.993RR (S TCMU TP 4.992 OU954.9914.99090 13 16 –50050100150 -0 –50050100150 -0 01 01 TEMPERATURE (°C) 33 TEMPERATURE (°C) 33 0 0 Figure 13. Output Voltage Swing High vs. Temperature Figure 16. CMRR vs. Temperature Rev. D | Page 7 of 20 Document Outline Features Applications Pin Configurations General Description Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings ESD Caution Thermal Resistance Typical Performance Characteristics Applications Theory of Operation Rail-to-Rail Output Stage Rail-to-Rail Input Stage Input Protection Overdrive Recovery Layout, Grounding, and Bypassing Considerations Power Supply Bypassing Grounding Leakage Currents Input Capacitance Output Capacitance Settling Time THD Readings vs. Common-Mode Voltage Driving a 16-Bit ADC Outline Dimensions Ordering Guide
