Datasheet AD8099 (Analog Devices) - 9
DescriptionUltralow Distortion, High Speed 0.95nV/√Hz Voltage Noise Op Amp
Pages / Page26 / 9 — Data Sheet. AD8099. –50. G = +5. VOUT = 2V p-p. –60 V. –60. S = ±5V. VS = …
RevisionE
File Format / SizePDF / 581 Kb
Data Sheet. AD8099. –50. G = +5. VOUT = 2V p-p. –60 V. –60. S = ±5V. VS = ±5V. RL = 1k. –70. dBc. –80. –90. –100. –110. HARMONIC DISTORTION (. –120
Data Sheet AD8099 –50 G = +5 VOUT = 2V p-p –60 V –60 S = ±5V VS = ±5V RL = 1k –70 dBc –80 –90 –100 –110 HARMONIC DISTORTION ( –120
Data Sheet AD8099 –50 –50 G = +5 G = +5 VOUT = 2V p-p VOUT = 2V p-p –60 V –60 S = ±5V VS = ±5V RL = 1k
RL = 1k
) ) –70 –70 dBc dBc –80 –80 –90 –90 –100 –100 –110 –110 HARMONIC DISTORTION ( HARMONIC DISTORTION ( –120 –120 SOLID LINE – SECOND HARMONIC SOLID LINE – SECOND HARMONIC DOTTED LINE – THIRD HARMONIC DOTTED LINE – THIRD HARMONIC –130 –130 0.1 1.0 10.0 0.1 1.0 10.0 FREQUENCY (MHz) FREQUENCY (MHz)
04511-A-009 04511-A-012 Figure 23. Harmonic Distortion vs. Frequency (SOIC) Figure 26. Harmonic Distortion vs. Frequency (LFCSP)
–40 –40 G = +2 G = +2 V V –50 OUT = 2V p-p OUT = 2V p-p V –50 S = ±5V VS = ±5V RL = 1k
RL = 1k
) –60 ) –60 dBc dBc –70 –70 –80 –80 –90 –90 –100 –100 –110 –110 HARMONIC DISTORTION ( HARMONIC DISTORTION ( –120 –120 SOLID LINES – SOLID LINE SECOND HARMONICS – SECOND HARMONIC SOLID LINE – SECOND HARMONIC DOTTED LINE – THIRD HARMONICS DOTTED LINE – THIRD HARMONIC DOTTED LINE – THIRD HARMONIC –130 –130 0.1 1.0 10.0 0.1 1.0 10.0 FREQUENCY (MHz) FREQUENCY (MHz)
04511-A-010 04511-A-013 Figure 24. Harmonic Distortion vs. Frequency (SOIC) Figure 27. Harmonic Distortion vs. Frequency (LFCSP)
–40 –40 G = –1 G = –1 V V –50 OUT = 2V p-p OUT = 2V p-p V –50 S = ±5V VS = ±5V RL = 1k
RL = 1k
) –60 ) –60 dBc dBc –70 –70 –80 –80 –90 –90 –100 –100 –110 –110 HARMONIC DISTORTION ( HARMONIC DISTORTION ( –120 –120 SOLID LINE – SECOND HARMONIC SOLID LINE – SECOND HARMONIC DOTTED LINE – THIRD HARMONIC DOTTED LINE – THIRD HARMONIC –130 –130 0.1 1.0 10.0 0.1 1.0 10.0 FREQUENCY (MHz)
04511-A-011
FREQUENCY (MHz)
04511-A-014 Figure 25. Harmonic Distortion vs. Frequency (SOIC) Figure 28. Harmonic Distortion vs. Frequency (LFCSP) Rev. E | Page 9 of 26 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAMS REVISION HISTORY SPECIFICATIONS SPECIFICATIONS WITH ±5 V SUPPLY SPECIFICATIONS WITH +5 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION USING THE AD8099 CIRCUIT COMPONENTS RECOMMENDED VALUES CIRCUIT CONFIGURATIONS PERFORMANCE vs. COMPONENT VALUES TOTAL OUTPUT NOISE CALCULATIONS AND DESIGN INPUT BIAS CURRENT AND DC OFFSET PIN AND INPUT BIAS CANCELLATION 16-BIT ADC DRIVER CIRCUIT CONSIDERATIONS PCB Layout Parasitics Grounding Power Supply Bypassing Component Selection DESIGN TOOLS AND TECHNICAL SUPPORT OUTLINE DIMENSIONS ORDERING GUIDE
