Datasheet AD8099 (Analog Devices) - 10
DescriptionUltralow Distortion, High Speed 0.95nV/√Hz Voltage Noise Op Amp
Pages / Page26 / 10 — AD8099. Data Sheet. –50. G = +10. RL = 1k. –60. S = ±2.5V. OUT = 1V p-p. …
RevisionE
File Format / SizePDF / 581 Kb
AD8099. Data Sheet. –50. G = +10. RL = 1k. –60. S = ±2.5V. OUT = 1V p-p. dBc. –70. –80. –90. –100. S = ±5V. HARMONIC DISTORTION (. VOUT = 2V p-p. –110
AD8099 Data Sheet –50 G = +10 RL = 1k –60 S = ±2.5V OUT = 1V p-p dBc –70 –80 –90 –100 S = ±5V HARMONIC DISTORTION ( VOUT = 2V p-p –110
AD8099 Data Sheet –50 –50 G = +10 G = +10 RL = 1k
RL = 1k
–60 –60 V V S = ±2.5V S = ±2.5V ) V ) V OUT = 1V p-p OUT = 1V p-p dBc –70 dBc –70 –80 –80 –90 –90 –100 –100 V V S = ±5V S = ±5V HARMONIC DISTORTION ( V HARMONIC DISTORTION ( VOUT = 2V p-p –110 OUT = 2V p-p –110 SOLID LINES – SECOND HARMONICS SOLID LINES – SECOND HARMONICS DOTTED LINES – THIRD HARMONICS DOTTED LINE – DOTTED LINES THIRD HARMONICS – THIRD HARMONICS –120 –120 0.1 1.0 10.0 0.1 1.0 10.0 FREQUENCY (MHz) FREQUENCY (MHz)
04511-A-015 04511-A-018 Figure 29. Harmonic Distortion vs. Frequency and Supply Voltage (SOIC) Figure 32. Harmonic Distortion vs. Frequency for Various Supplies (LFCSP
–40 –40 G = +5 G = +5 VS = ±5V VS = ±5V –50 f = 10MHz –50 f = 10MHz RL = 100
RL = 100
) ) dBc –60 dBc –60 –70 –70 –80 –80 –90 –90 HARMONIC DISTORTION ( HARMONIC DISTORTION ( –100 –100 SOLID LINE – SECOND HARMONIC SOLID LINE – SECOND HARMONIC DOTTED LINE – THIRD HARMONIC DOTTED LINE – THIRD HARMONIC –110 –110 1 2 3 4 5 6 7 1 2 3 4 5 6 7 OUTPUT AMPLITUDE (V p-p) OUTPUT AMPLITUDE (V p-p)
04511-A-016 04511-A-019 Figure 30. Harmonic Distortion vs. Output Amplitude (SOIC) Figure 33. Harmonic Distortion vs. Output Amplitude (LFCSP)
–40 –40 G = +5 G = +5 VS = ±5V VS = ±5V –50 f = 10MHz –50 f = 10MHz RL = 1k
RL = 1k
) ) –60 –60 dBc dBc –70 –70 –80 –80 –90 –90 –100 –100 HARMONIC DISTORTION ( HARMONIC DISTORTION ( –110 –110 SOLID LINE – SECOND HARMONIC SOLID LINE – SECOND HARMONIC DOTTED LINE – THIRD HARMONIC DOTTED LINE – THIRD HARMONIC –120 –120 1 2 3 4 5 6 7 1 2 3 4 5 6 7 OUTPUT AMPLITUDE (V p-p) OUTPUT AMPLITUDE (V p-p)
04511-A-017 04511-A-021 Figure 31. Harmonic Distortion vs. Output Amplitude (SOIC) Figure 34. Harmonic Distortion vs. Output Amplitude (LFCSP) Rev. E | Page 10 of 26 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAMS REVISION HISTORY SPECIFICATIONS SPECIFICATIONS WITH ±5 V SUPPLY SPECIFICATIONS WITH +5 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION USING THE AD8099 CIRCUIT COMPONENTS RECOMMENDED VALUES CIRCUIT CONFIGURATIONS PERFORMANCE vs. COMPONENT VALUES TOTAL OUTPUT NOISE CALCULATIONS AND DESIGN INPUT BIAS CURRENT AND DC OFFSET PIN AND INPUT BIAS CANCELLATION 16-BIT ADC DRIVER CIRCUIT CONSIDERATIONS PCB Layout Parasitics Grounding Power Supply Bypassing Component Selection DESIGN TOOLS AND TECHNICAL SUPPORT OUTLINE DIMENSIONS ORDERING GUIDE
