Datasheet AD8016 (Analog Devices) - 8
Description | Full Rate ADSL Line Driver With Powerdown |
Pages / Page | 20 / 8 — AD8016. Data Sheet. –30. (0,0). F = 499Ω. RF = 499Ω. G = +10. –40 VOUT = … |
Revision | C |
File Format / Size | PDF / 492 Kb |
AD8016. Data Sheet. –30. (0,0). F = 499Ω. RF = 499Ω. G = +10. –40 VOUT = 4V p-p. (0,1). –50. (1,0). B –60. d –60. –70. TION. TION –70
AD8016 Data Sheet –30 –30 R (0,0) F = 499Ω RF = 499Ω G = +10 G = +10 –40 VOUT = 4V p-p (0,1) –40 VOUT = 4V p-p (0,0) –50 –50 (1,0) (0,1) (1,0) c) c) B –60 B d d –60 ( ( –70 TION TION –70 OR OR PWDN1, PWDN0 = (1,1) T T –80 IS IS –80 D PWDN1, PWDN0 = (1,1) D –90 –90 –100 –100 –110
6 13
–110 0.01 0.1 1 10 20
0
0.01 0.1 1 10 20
-01 9 1
FREQUENCY (MHz)
0 1019-
FREQUENCY (MHz)
0 01 Figure 12. Distortion vs. Frequency; Second Harmonic, VS = ±6 V, RL = 50 Ω Figure 15. Distortion vs. Frequency; Third Harmonic, VS = ±6 V, RL = 50 Ω, Differential
–30 –30 RF = 499Ω RF = 499Ω G = +5 G = +5 –35 –40 –40 (1,0) –45 (0,0) c) –50 Bc) B d d ( –50 N (0,1) N ( IO IO T –55 T –60 R (0,0) (0,1) (1,0) R O O T –60 T S S DI DI –70 –65 –70 –80 –75 PWDN1, PWDN0 = (1,1) PWDN1, PWDN0 = (1,1) –80
4
–90 0 100 200 300 400 500 600 700 800
01 017 9-
19-
PEAK OUTPUT CURRENT (mA)
01 01
010 Figure 13. Distortion vs. Peak Output Current; Second Harmonic, VS = ±12 V, Figure 16. Distortion vs. Peak Output Current, Third Harmonic; VS = ±12 V, RL = 10 Ω, f = 100 kHz, Single-Ended RL = 10 Ω, G = +5, f = 100 kHz, Single-Ended
–30 –30 R (0,0) F = 499Ω RF = 499Ω G = +10 G = +5 –35 –40 VOUT = 4V p-p (0,1) –40 –50 –45 c) c) B B (0,0) d –60 (1,0) d ( ( –50 (0,1) ON TION –70 TI –55 (1,0) OR PWDN1, PWDN0 = (1,1) OR T T –60 IS –80 IS D D –65 –90 –70 –100 –75 PWDN1, PWDN0 = (1,1) –110 –80
018
0.01 0.1 1 10 20
-015
9-
FREQUENCY (MHz) PEAK OUTPUT CURRENT (mA)
01019 0101 Figure 14. Distortion vs. Frequency; Third Harmonic, VS = ±12 V, RL = 50 Ω, Figure 17. Distortion vs. Peak Output Current; Second Harmonic, VS = ±6 V, Differential RL = 5 Ω, f = 100 kHz, Single-Ended Rev. C | Page 8 of 20 Document Outline Features Pin Configurations General Description Revision History Specifications Logic Inputs (CMOS Compatible Logic) Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuts Theory of Operation Power Supply and Decoupling Feedback Resistor Selection Bias Pin and PWDN Features Thermal Shutdown Applications Information Multitone Power Ratio (MTPR) Generating DMT Power Dissipation Thermal Enhancements and PCB Layout Thermal Testing Air Flow Test Conditions DUT Power Thermal Resistance PCB Dimensions of a Differential Driver Circuit Experimental Results Outline Dimensions Ordering Guide
