Datasheet AD8016 (Analog Devices) - 10
DescriptionFull Rate ADSL Line Driver With Powerdown
Pages / Page20 / 10 — AD8016. Data Sheet. G = +5. L = 100Ω. F = 499Ω. RF = 499Ω. OLTA. T V. …
RevisionC
File Format / SizePDF / 492 Kb
AD8016. Data Sheet. G = +5. L = 100Ω. F = 499Ω. RF = 499Ω. OLTA. T V. –10. –13. –16. –19. 100. 500. FREQUENCY (MHz). VIN = 2V rms. F = 602Ω. –20. (1,1)
AD8016 Data Sheet G = +5 L = 100Ω F = 499Ω RF = 499Ω OLTA T V –10 –13 –16 –19 100 500 FREQUENCY (MHz) VIN = 2V rms F = 602Ω –20 (1,1)
AD8016 Data Sheet 11 11 G = +5 G = +5 R R 8 L = 100Ω L = 100Ω R 8 F = 499Ω RF = 499Ω 5 5 ) ) V V 2 2 dB dB ( ( GE –1 GE –1 –4 –4 OLTA OLTA T V –7 T V –7 U U TP TP –10 –10 OU OU –13 –13 –16 –16 –19 –19
026 029
1 10 100 500 1 10 100 500 FREQUENCY (MHz) FREQUENCY (MHz)
01019- 01019- Figure 24. Output Voltage vs. Frequency; VS = ±12 V Figure 27. Output Voltage vs. Frequency; VS = ±6 V
20 –10 VIN = 2V rms RF = 499Ω R 10 F = 602Ω –20 (1,1) 0 (1,0) –30 –10 +PSRR –40 B) –20 B) d d –30 –50 RR ( (0,1) RR ( S –PSRR CM –40 P –60 (0,0) –50 –70 –60 –80 –70 –80 –90
027 030
0.03 0.1 1 10 100 500 0.01 0.1 1 10 100 500 FREQUENCY (MHz)
01019-
FREQUENCY (MHz)
01019- Figure 25. CMRR vs. Frequency; VS = ±12 V @ PWDN1, PWDN0 Codes Figure 28. PSRR vs. Frequency; VS = ±12 V
6 180 90 B) d 3 160 ( 80 E ) ) z 0 NS Hz 140 70 O (1,1) / H A/ P p S –3 nV ( E 120 60 ( E RE IS –6 OIS 100 NCY 50 NO N –9 (1,0) UE NT GE Q 80 40 –12 RE (0,1) OLTA D F CURRE 60 30 E –15 +INOISE T V UT IZ U NP 40 20 P AL –18 (0,0) I VIN NOISE IN + RM V –21 IN = 40mV p-p 20 10 NO G = +5 RL = 100Ω –24 0 0
028 031
1 10 100 500 10 100 1k 10k 100k 1M 10M FREQUENCY (MHz)
01019-
FREQUENCY (MHz)
01019- Figure 26. Frequency Response; VS = ±6 V, @ PWDN1, PWDN0 Codes Figure 29. Noise vs. Frequency Rev. C | Page 10 of 20 Document Outline Features Pin Configurations General Description Revision History Specifications Logic Inputs (CMOS Compatible Logic) Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Test Circuts Theory of Operation Power Supply and Decoupling Feedback Resistor Selection Bias Pin and PWDN Features Thermal Shutdown Applications Information Multitone Power Ratio (MTPR) Generating DMT Power Dissipation Thermal Enhancements and PCB Layout Thermal Testing Air Flow Test Conditions DUT Power Thermal Resistance PCB Dimensions of a Differential Driver Circuit Experimental Results Outline Dimensions Ordering Guide
