Datasheet AD8004 (Analog Devices) - 2
DescriptionQuad 3000 V/s, 35 mW Current Feedback Amplifier
Pages / Page16 / 2 — AD8004–SPECIFICATIONS (@ TA = +25. C, VS =. 5 V, RL = 100. , unless …
RevisionD
File Format / SizePDF / 348 Kb
AD8004–SPECIFICATIONS (@ TA = +25. C, VS =. 5 V, RL = 100. , unless otherwise noted.). AD8004A. AD8004S. Parameter
AD8004–SPECIFICATIONS (@ TA = +25 C, VS = 5 V, RL = 100 , unless otherwise noted.) AD8004A AD8004S Parameter
AD8004–SPECIFICATIONS (@ TA = +25 C, VS = 5 V, RL = 100 , unless otherwise noted.) AD8004A AD8004S Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
DYNAMIC PERFORMANCE Bandwidth for 0.1 dB Flatness 30 30 MHz G = +2 Slew Rate 3000 3000 V/ G = +2, V µs O = 4 V Step 2000 2000 V/ G = –2, V µs O = 4 V Step Settling Time to 0.1% 21 21 ns G = +2, VO = 2 V Step Rise and Fall Time (10% to 90%) G = +2, VO = 2 V Step 1.8 1.8 ns NOISE/HARMONIC PERFORMANCE Total Harmonic Distortion f –78 –78 dBc C = 5 MHz, VO = 2 V p-p, RL = 1 kΩ Crosstalk, R Package, Worst Case f = 5 MHz, G = +2, R –69 dB L = 1 kΩ Input Voltage Noise f = 10 kHz 1.5 1.5 nV/√Hz Input Current Noise f = 10 kHz, +In 38 38 pA/√Hz –In 38 38 pA/√Hz Differential Gain Error NTSC, G = +2, RL = 150 Ω, RF = 1.21 kΩ 0.04 0.04 % Differential Phase Error NTSC, G = +2, RL = 150 Ω, RF = 1.21 kΩ 0.10 0.10 Degree Differential Gain Error NTSC, G = +2, RL = 1 kΩ, RF = 1.21 kΩ 0.01 0.01 % Differential Phase Error NTSC, G = +2, RL = 1 kΩ, RF = 1.21 kΩ 0.04 0.04 Degree DC PERFORMANCE Input Offset Voltage 1.0 3.5 1.0 3.5 mV TMIN to TMAX 1.5 5 1.5 6 mV Offset Drift 15 15 µV/°C –Input Bias Current ±35 ±90 ±35 ±90 µA TMIN to TMAX ±110 ±120 µA +Input Bias Current ±40 ±110 ±40 ±110 µA TMIN to TMAX ±120 ±130 µA Open-Loop Transresistance VO = ±2.5 V 170 290 170 290 kΩ TMIN to TMAX 220 220 kΩ INPUT CHARACTERISTICS Input Resistance +Input 2 2 MΩ –Input 50 50 Ω Input Capacitance +Input 1.5 1.5 pF Input Common-Mode Voltage Range 3.2 3.2 ±V Common-Mode Rejection Ratio Offset Voltage VCM = ±2.5 V 52 58 52 58 dB –Input Current VCM = ±2.5 V, TMIN to TMAX 1 1 µA/V +Input Current VCM = ±2.5 V, TMIN to TMAX 12 12 µA/V OUTPUT CHARACTERISTICS Output Voltage Swing RL = 150 Ω 3.9 3.9 ±V Output Current 50 50 mA Short Circuit Current 100 180 100 180 mA POWER SUPPLY Operating Range ±2.0 ±6.0 ±2.0 ±6.0 V Total Quiescent Current 14 17 14 17 mA TMIN to TMAX 16 20 16 23 mA Power Supply Rejection Ratio ∆VS = ±2 V 56 62 56 62 dB –Input Current TMIN to TMAX 0.5 0.5 µA/V +Input Current TMIN to TMAX 4 4 µA/V Specifications subject to change without notice. –2– REV. D Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE MAXIMUM POWER DISSIPATION Typical Performance Characteristics THEORY OF OPERATION DC AND AC CHARACTERISTICS DRIVING CAPACITIVE LOADS OPTIMIZING FLATNESS DRIVING A SINGLE-SUPPLY A/D CONVERTER LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS Revision History
