Datasheet AD8004 (Analog Devices) - 3
DescriptionQuad 3000 V/s, 35 mW Current Feedback Amplifier
Pages / Page16 / 3 — SPECIFICATIONS (@ TA = +25. C, VS = +5 V, RL = 100. , unless otherwise …
RevisionD
File Format / SizePDF / 348 Kb
SPECIFICATIONS (@ TA = +25. C, VS = +5 V, RL = 100. , unless otherwise noted.). AD8004. AD8004A. AD8004S. Parameter
SPECIFICATIONS (@ TA = +25 C, VS = +5 V, RL = 100 , unless otherwise noted.) AD8004 AD8004A AD8004S Parameter
SPECIFICATIONS (@ TA = +25 C, VS = +5 V, RL = 100 , unless otherwise noted.) AD8004 AD8004A AD8004S Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
DYNAMIC PERFORMANCE Bandwidth for 0.1 dB Flatness G = +2 30 30 MHz Slew Rate G = +2, V 1100 1100 V/ O = 2 V Step µs Settling Time to 0.1% G = +2, VO = 2 V Step 24 24 ns Rise and Fall Time (10% to 90%) G = +2, VO = 2 V Step 2.3 2.3 ns NOISE/HARMONIC PERFORMANCE Total Harmonic Distortion fC = 5 MHz, VO = 2 V p-p, RL = 1 kΩ –65 –65 dBc Crosstalk, R Package, Worst Case f = 5 MHz, G = +2, RL = 1 kΩ –69 dB Input Voltage Noise f = 10 kHz 1.5 1.5 nV/√Hz Input Current Noise f = 10 kHz, +In 38 38 pA/√Hz –In 38 38 pA/√Hz Differential Gain Error NTSC, G = +2, RL = 150 Ω, RF = 1.21 kΩ 0.06 0.06 % Differential Phase Error NTSC, G = +2, RL = 150 Ω, RF = 1.21 kΩ 0.25 0.25 Degree Differential Gain Error NTSC, G = +2, RL = 1 kΩ, RF = 1.21 kΩ 0.01 0.01 % Differential Phase Error NTSC, G = +2, RL = 1 kΩ, RF = 1.21 kΩ 0.08 0.08 Degree DC PERFORMANCE Input Offset Voltage 1.0 2.5 1.0 2.5 mV TMIN to TMAX 1 3 1 4 mV Offset Drift 15 15 µV/°C –Input Bias Current ±20 ±80 ±20 ±80 µA T ± MIN to TMAX 100 ±110 µA +Input Bias Current ±35 ±100 ±35 ±100 µA TMIN to TMAX ±115 ±125 µA Open Loop Transresistance VO = +1.5 V to +3.5 V 140 230 140 230 kΩ TMIN to TMAX 170 170 kΩ INPUT CHARACTERISTICS Input Resistance +Input 2 2 MΩ –Input 50 50 Ω Input Capacitance +Input 1.5 1.5 pF Input Common-Mode Voltage Range 3.2 3.2 V Common-Mode Rejection Ratio Offset Voltage VCM = +1 V to +3 V 52 57 52 57 dB –Input Current VCM = +1 V to +3 V, TMIN to TMAX 2 2 µA/V +Input Current VCM = +1 V to +3 V, TMIN to TMAX 15 15 µA/V OUTPUT CHARACTERISTICS Output Voltage Swing RL = 150 Ω 0.9 to 4.1 0.9 to 4.1 V Output Current 50 50 mA Short Circuit Current 95 95 mA POWER SUPPLY Operating Range 0, +4 +12 0, +4 +12 V Total Quiescent Current 13 14 13 14 mA TMIN to TMAX 14.5 15.5 14.5 17.5 mA Power Supply Rejection Ratio ∆VS = +1 V, VCM = +2.5 V 56 62 56 62 dB –Input Current TMIN to TMAX 1 1 µA/V +Input Current TMIN to TMAX 6 6 µA/V Specifications subject to change without notice. REV. D –3– Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE MAXIMUM POWER DISSIPATION Typical Performance Characteristics THEORY OF OPERATION DC AND AC CHARACTERISTICS DRIVING CAPACITIVE LOADS OPTIMIZING FLATNESS DRIVING A SINGLE-SUPPLY A/D CONVERTER LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS Revision History
