Datasheet AD810 (Analog Devices) - 3
DescriptionLow Power Video Op Amp with Disable
Pages / Page22 / 3 — Data Sheet. AD810. SPECIFICATIONS. Table 1. AD810A. 5962-9313201MPA1. …
File Format / SizePDF / 472 Kb
Data Sheet. AD810. SPECIFICATIONS. Table 1. AD810A. 5962-9313201MPA1. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet AD810 SPECIFICATIONS Table 1 AD810A 5962-9313201MPA1 Parameter Test Conditions/Comments Min Typ Max Unit
link to page 4 link to page 4
TA = 25°C, supply voltage (VS) = ±15 V dc, load resistance (RL) = 150 Ω, unless otherwise noted.
Table 1. AD810A 5962-9313201MPA1 Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
DYNAMIC PERFORMANCE −3 dB Bandwidth G = +2, feedback resistor (RF) = 40 50 40 50 MHz 715 Ω, VS = ±5 V G = +2, RF = 715 Ω, VS = ±15 V 55 75 55 75 MHz G = +1, RF = 1000 Ω, VS = ±15 V 40 80 40 80 MHz G = +10, RF = 270 Ω, VS = ±15 V 50 65 50 65 MHz 0.1 dB Bandwidth G = +2, RF = 715 Ω, VS = ±5 V 13 22 13 22 MHz G = +2, RF = 715 Ω, VS = ±15 V 15 30 15 30 MHz Full Power Bandwidth Output voltage (VOUT) = 20 V p-p RL = 400 Ω 16 8 16 MHz Slew Rate2 RL = 150 Ω, VS = ±5 V 350 175 350 V/µs RL = 400 Ω, VS = ±15 V 1000 500 1000 V/µs Settling Time to 0.1% 10 V step, G = −1 50 50 ns Settling Time to 0.01% 10 V step, G = −1 125 125 ns Differential Gain f = 3.58 MHz, VS = ±15 V 0.02 0.05 0.02 0.05 % f = 3.58 MHz, VS = ±5 V 0.04 0.07 0.04 0.07 % Differential Phase f = 3.58 MHz, VS = ±15 V 0.04 0.07 0.04 0.07 Degrees f = 3.58 MHz, VS = ±5 V 0.045 0.08 0.045 0.08 Degrees Total Harmonic f = 10 MHz, VOUT = 2 V p-p Distortion RL = 400 Ω, G = +2 −61 −61 dBc INPUT OFFSET VOLTAGE VS = ±5 V and ±15 V 1.5 6 1.5 6 mV TMIN to TMAX, VS = ±5 V and ±15 V 2 7.5 4 15 mV Offset Voltage Drift 7 15 µV/°C INPUT BIAS CURRENT Negative Input TMIN to TMAX, VS = ±5 V and ±15 V 0.7 5 0.8 5 µA Positive Input TMIN to TMAX, VS = ±5 V and ±15 V 2 7.5 2 10 µA OPEN-LOOP TMIN to TMAX TRANSRESISTANCE VOUT = ±10 V, RL = 400 Ω, VS = ±15 V 1.0 3.5 1.0 3.5 MΩ VOUT = ±2.5 V, RL = 100 Ω, VS = ±5 V 0.3 1.2 0.2 1.0 MΩ OPEN-LOOP DC VOLTAGE TMIN to TMAX GAIN VOUT = ±10 V, RL = 400 Ω, VS = ±15 V 86 100 80 100 dB VOUT = ±2.5 V, RL = 100 Ω, VS = ±5 V 76 88 72 88 dB COMMON-MODE TMIN to TMAX REJECTION Offset Voltage (VOS) Common-mode voltage (VCM) = ±12 V, 56 64 56 64 dB VS = ±15 V VCM = ±2.5 V, VS = ±5 V 52 60 50 60 dB Input Bias Current TMIN to TMAX, VS = ±5 V and ±15 V 0.1 0.4 −0.4 0.1 +0.4 µA/V POWER SUPPLY REJECTION VOS TMIN to TMAX, VS = ±4.5 V to ±18 V 65 72 60 72 dB Input Bias Current TMIN to TMAX 0.05 0.3 −0.3 0.05 +0.3 µA/V INPUT VOLTAGE NOISE f = 1 kHz, VS = ±5 V and ±15 V 2.9 2.9 nV/√Hz INPUT CURRENT NOISE Negative input current (–IIN), 13 13 pA/√Hz f = 1 kHz, VS = ±5 V and ±15 V Positive input current (+IIN), f = 1 kHz, 1.5 1.5 pA/√Hz VS = ±5 V and ±15 V INPUT COMMON-MODE VS = ±5 V ±2.5 ±3.0 ±2.5 ±3 V VOLTAGE RANGE VS = ±15 V ±12 ±13 ±12 ±13 V Rev. B | Page 3 of 22 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION GENERAL DESIGN CONSIDERATIONS ACHIEVING VERY FLAT GAIN RESPONSE AT HIGH FREQUENCY CHOICE OF FEEDBACK RESISTOR PRINTED CIRCUIT BOARD LAYOUT QUALITY OF COAXIAL CABLE POWER SUPPLY BYPASSING POWER SUPPLY OPERATING RANGE OFFSET NULLING DISABLE MODE APPLICATIONS INFORMATION CAPACITIVE LOADS OPERATION AS A VIDEO LINE DRIVER 2:1 VIDEO MULTIPLEXER 4:1 MULTIPLEXER OUTLINE DIMENSIONS ORDERING GUIDE
