Datasheet AD810 (Analog Devices) - 4
DescriptionLow Power Video Op Amp with Disable
Pages / Page22 / 4 — AD810. Data Sheet. AD810A. 5962-9313201MPA1. Parameter. Test …
File Format / SizePDF / 472 Kb
AD810. Data Sheet. AD810A. 5962-9313201MPA1. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
AD810 Data Sheet AD810A 5962-9313201MPA1 Parameter Test Conditions/Comments Min Typ Max Unit
link to page 19 link to page 8 link to page 19
AD810 Data Sheet AD810A 5962-9313201MPA1 Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
OUTPUT CHARACTERISTICS Output Voltage Swing3 RL = 150 Ω, TMIN to TMAX, VS = ±5 V ±2.5 ±2.9 ±2.5 ±2.9 V RL = 400 Ω, VS = ±15 V ±12.5 ±12.9 ±12.5 ±12.9 V RL = 400 Ω, TMIN to TMAX, VS = ±15 V ±12 ±12 V Short-Circuit Current 150 150 mA Output Current TMIN to TMAX, VS = ±5 V and ±15 V 40 60 30 60 mA OUTPUT RESISTANCE Open loop (5 MHz) 15 15 Ω INPUT CHARACTERISTICS Input Resistance Positive input 2.5 10 2.5 10 MΩ Negative input 40 40 Ω Input Capacitance Positive input 2 2 pF DISABLE CHARACTERISTICS4 Off Isolation f = 5 MHz, see Figure 59 64 64 dB Off Output Resistance See Figure 15, RG is gain resistor (RF + RG)||13 pF (RF + RG)||13 pF Ω Turn On Time5 Output impedance (ZOUT) = low, see 170 170 ns Figure 59 Turn Off Time ZOUT = high 100 100 ns DISABLE Pin Current DISABLE pin = 0 V, VS = ±5 V 50 75 50 75 µA DISABLE pin = 0 V, VS = ±15 V 290 400 290 400 µA Minimum DISABLE Pin TMIN to TMAX, VS = ±5 V and ±15 V 30 10 30 40 µA Current to Disable POWER SUPPLY Operating Range 25°C to TMAX ±2.5 ±18 ±2.5 ±18 V TMIN ±3.0 ±18 ±3.5 ±18 V Quiescent Current VS = ±5 V 6.7 7.5 6.7 7.5 mA VS = ±15 V 6.8 8.0 6.8 8.0 mA TMIN to TMAX, VS = ±5 V and ±15 V 8.3 10.0 9 11.0 mA Power-Down Current VS = ±5 V 1.8 2.3 1.8 2.3 mA VS = ±15 V 2.1 2.8 2.1 2.8 mA TEMPERATURE Operating Range (TMIN to −40 +85 −55 +125 °C TMAX) 1 See the Analog Devices military data sheet for 883B specifications. 2 Slew rate measurement is based on 10% to 90% rise time with the amplifier configured for a gain of −10. 3 Voltage swing is defined as useful operating range, not the saturation range. 4 Disable guaranteed break before make. 5 Turn on time is defined with ±5 V supplies using complementary output CMOS to drive the disable pin. Rev. B | Page 4 of 22 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION GENERAL DESIGN CONSIDERATIONS ACHIEVING VERY FLAT GAIN RESPONSE AT HIGH FREQUENCY CHOICE OF FEEDBACK RESISTOR PRINTED CIRCUIT BOARD LAYOUT QUALITY OF COAXIAL CABLE POWER SUPPLY BYPASSING POWER SUPPLY OPERATING RANGE OFFSET NULLING DISABLE MODE APPLICATIONS INFORMATION CAPACITIVE LOADS OPERATION AS A VIDEO LINE DRIVER 2:1 VIDEO MULTIPLEXER 4:1 MULTIPLEXER OUTLINE DIMENSIONS ORDERING GUIDE
