Datasheet AD829 (Analog Devices) - 6
DescriptionHigh Speed, Low Noise Video Op Amp
Pages / Page20 / 6 — AD829. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 6.0. 5.5. +VOUT. …
RevisionI
File Format / SizePDF / 381 Kb
AD829. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 6.0. 5.5. +VOUT. 5.0. –VOUT. QUIESCENT CURRENT (mA). 4.5
AD829 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 6.0 5.5 +VOUT 5.0 –VOUT QUIESCENT CURRENT (mA) 4.5
AD829 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 20 6.0 15 5.5 +VOUT 10 5.0 –VOUT 5 QUIESCENT CURRENT (mA) 4.5 INPUT COMMON-MODE RANGE (V)
00880-005
0
00880-008
4.0 0 5 10 15 20 0 5 10 15 20 SUPPLY VOLTAGE (
V) SUPPLY VOLTAGE (
V)
Figure 5. Input Common-Mode Range vs. Supply Voltage Figure 8. Quiescent Current vs. Supply Voltage
20 –5 ) V ( GE 15 OLTA +V
µ
A) OUT T V –4 U TP OU 10 E VS =
5V,
15V –VOUT OF TH –3 E D 5 INPUT BIAS CURRENT ( ITU GN A RL = 1kΩ
006
M
00880-
0
00880-009
–2 0 5 10 15 20 –60 –40 –20 0 20 40 60 80 100 120 140 SUPPLY VOLTAGE (±V) TEMPERATURE (
C)
Figure 6. Output Voltage Swing vs. Supply Voltage Figure 9. Input Bias Current vs. Temperature
30 100 )
± Ω
25 15V SUPPLIES 10 AV = 20 20 CCOMP = 0pF 1 15 0.1 10 AV = 1 CCOMP = 68pF OUTPUT VOLTAGE SWING (V p-p)
0.01 5 5V SUPPLIES CLOSED-LOOP OUTPUT IMPEDANCE (
00880-007
0
00880-010
0.001 10 100 1k 10k 1k 10k 100k 1M 10M 100M LOAD RESISTANCE (
) FREQUENCY (Hz)
Figure 7. Output Voltage Swing vs. Resistive Load Figure 10. Closed-Loop Output Impedance vs. Frequency Rev. I | Page 6 of 20 Document Outline Features General Description Connection Diagram Product Highlights Revision History Specifications Absolute Maximum Ratings Thermal Characteristics Metallization Photo ESD Caution Typical Performance Characteristics Test Circuits Theory of Operation Externally Compensating the AD829 Shunt Compensation Current Feedback Compensation Low Error Video Line Driver High Gain Video Bandwidth, 3-Op-Amp Instrumentation Amplifier Outline Dimensions Ordering Guide
