Datasheet AD829 (Analog Devices) - 7
DescriptionHigh Speed, Low Noise Video Op Amp
Pages / Page20 / 7 — Data Sheet. AD829. 120. 100. PHASE. GAIN. 15V SUPPLIES. LOAD. VS =. 15V. …
RevisionI
File Format / SizePDF / 381 Kb
Data Sheet. AD829. 120. 100. PHASE. GAIN. 15V SUPPLIES. LOAD. VS =. 15V. SUPPLIES 500. PHASE (Degrees). OPEN-LOOP GAIN (dB)
Data Sheet AD829 120 100 PHASE GAIN 15V SUPPLIES LOAD VS = 15V SUPPLIES 500 PHASE (Degrees) OPEN-LOOP GAIN (dB)
Data Sheet AD829 7 120 100 PHASE 100 80 GAIN 6
15V SUPPLIES 80 60 1k
LOAD VS =
15V 5 60 GAIN 40
5V VS =
5V SUPPLIES 500
LOAD PHASE (Degrees) 40 20 OPEN-LOOP GAIN (dB) QUIESCENT CURRENT (mA) 4 20 0 CCOMP = 0pF
00880-011
3
00880-014
0 –20 –60 –40 –20 0 20 40 60 80 100 120 140 100 1k 10k 100k 1M 10M 100M TEMPERATURE (
C) FREQUENCY (Hz)
Figure 11. Quiescent Current vs. Temperature Figure 14. Open-Loop Gain and Phase vs. Frequency
40 105 NEGATIVE CURRENT LIMIT mA) 100 ( 35 IT VS =
15V IM POSITIVE L CURRENT LIMIT 95 NT 30 VS =
5V 90 CURRE T 25 RCUI 85 -CI OPEN-LOOP GAIN (dB) RT 20 HO 80 S V
012
S = ±5V
00880-
15
00880-015
75 –60 –40 –20 0 20 40 60 80 100 120 140 10 100 1k 10k AMBIENT TEMPERATURE (°C) LOAD RESISTANCE (
Figure 12. Short-Circuit Current Limit vs. Ambient Temperature Figure 15. Open-Loop Gain vs. Resistive Load
65 120 VS = ±15V AV = +20 +SUPPLY CCOMP = 0pF 100 ) 60 Hz –SUPPLY M H ( 80 IDT 55 PSRR (dB) 60 B BANDW –3d 50 40 C
013
COMP = 0pF
00880-
45
00880-016
20 –60 –40 –20 0 20 40 60 80 100 120 140 1k 10k 100k 1M 10M 100M TEMPERATURE (°C) FREQUENCY (Hz)
Figure 13. –3 dB Bandwidth vs. Temperature Figure 16. Power Supply Rejection Ratio (PSRR) vs. Frequency Rev. I | Page 7 of 20 Document Outline Features General Description Connection Diagram Product Highlights Revision History Specifications Absolute Maximum Ratings Thermal Characteristics Metallization Photo ESD Caution Typical Performance Characteristics Test Circuits Theory of Operation Externally Compensating the AD829 Shunt Compensation Current Feedback Compensation Low Error Video Line Driver High Gain Video Bandwidth, 3-Op-Amp Instrumentation Amplifier Outline Dimensions Ordering Guide
