Datasheet AD708 (Analog Devices) - 5
DescriptionUltralow Offset Voltage Dual Op Amp
Pages / Page16 / 5 — Data Sheet. AD708. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. Rating. …
RevisionD
File Format / SizePDF / 343 Kb
Data Sheet. AD708. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. Rating. ESD CAUTION
Data Sheet AD708 ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
Data Sheet AD708 ABSOLUTE MAXIMUM RATINGS Table 2.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a Supply Voltage ±22 V stress rating only; functional operation of the product at these Internal Power Dissipation1 or any other conditions above those indicated in the operational Input Voltage2 ±VS section of this specification is not implied. Operation beyond Output Short-Circuit Duration Indefinite the maximum operating conditions for extended periods may Differential Input Voltage +VS and −VS affect product reliability. Storage Temperature Range (Q) −65°C to +150°C
ESD CAUTION
Storage Temperature Range (N) −65°C to +125°C Lead Temperature (Soldering 60 sec) 300°C 1 Thermal Characteristics 8-lead PDIP: θJC = 33°C/W, θJA = 100°C/W 8-lead CERDIP: θJC = 30°C/W, θJA = 110°C/W 2 For supply voltages less than ±22 V, the absolute maximum input voltage is equal to the supply voltage. Rev. D | Page 5 of 16 Document Outline Features Pin Configuration General Description Product Highlights Revision History Specifications Absolute Maximum Ratings ESD Caution Typical Performance Characteristics Matching Characteristics Theory of Operation Crosstalk Performance Operation with a Gain of −100 High Precision Programmable Gain Amplifier Bridge Signal Conditioner Precision Absolute Value Circuit Selection of Passive Components Outline Dimensions Ordering Guide
