Datasheet OP37 (Analog Devices) - 10
DescriptionLow Noise, Precision, High Speed Operational Amplifier (AVCL≥5)
Pages / Page16 / 10 — OP37. 0.1. 2.4. TA = 25. 1 SEC/DIV. V 2.2. VS =. 15V. 100k. V/ 2.0. 1.8. …
RevisionB
File Format / SizePDF / 575 Kb
OP37. 0.1. 2.4. TA = 25. 1 SEC/DIV. V 2.2. VS =. 15V. 100k. V/ 2.0. 1.8. D.U.T. 1.6. GE GAIN –. TA 1.4. VOLTAGE. OL V. GAIN. 1.2. 4.3k. = 50,000. OP12. 1.0. 4.7. SCOPE
OP37 0.1 2.4 TA = 25 1 SEC/DIV V 2.2 VS = 15V 100k V/ 2.0 1.8 D.U.T 1.6 GE GAIN – TA 1.4 VOLTAGE OL V GAIN 1.2 4.3k = 50,000 OP12 1.0 4.7 SCOPE
OP37 0.1 F 2.4 TA = 25 C 1 SEC/DIV V 2.2 VS = 15V 100k V/ 2.0 1.8 OP37 10 D.U.T. 1.6 GE GAIN – 2k TA 1.4 VOLTAGE OL V GAIN 22 F 1.2 4.3k = 50,000 OP12 1.0 4.7 F SCOPE 1 R 100k IN = 1M 0.8 2.2 F 110k OPEN-LOOP 0.6 0.1 F 0.4 24.3k 100 1k 10k 100k LOAD RESISTANCE –
TPC 28. Noise Test Circuit (0.1 Hz to TPC 29. Low-Frequency Noise TPC 30. Open-Loop Voltage Gain vs. 10 Hz) Load Resistance
160 19 20 TA = 25 C T T 140 A = 25 C A = 25 C VS = 15V AVCL = 5 RISE TIO – dB AV = 5 120 18 V s 15 V O = 20V p-p V/ 100 FALL V/ NEGATIVE 80 TE – 17 SWING OISE – 10 N Y REJECTION RA E 60 G POSITIVE SLEW RA LTA 40 SWING 16 VO 5 WER SUPPL 20 PO 0 15 0 1 10 100 1k 10k 100k 1M 10M 100M 100 1k 10k 100k 3 6 9 12 15 18 21 FREQUENCY – Hz LOAD RESISTANCE – SUPPLY VOLTAGE – Volts
TPC 31. PSRR vs. Frequency TPC 32. Slew Rate vs. Load TPC 33. Slew Rate vs. Supply Voltage –10– REV. B Document Outline FEATURES GENERAL DESCRIPTION PIN CONNECTIONS SIMPLIFIED SCHEMATIC ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE SPECIFICATIONS BINDING DIAGRAM Wafer Test Limits Typical Electrical Characteristics Typical Performance Characteristics APPLICATIONS INFORMATION Offset Voltage Adjustment Noise Measurements Optimizing Linearity Instrumentation Amplifier Comments on Noise Audio Applications OUTLINE DIMENSIONS Revision History
