Datasheet SiZ240DT (Vishay) - 10
ManufacturerVishay
DescriptionDual N-Channel 40 V (D-S) MOSFETs
Pages / Page14 / 10 — SiZ240DT. CHANNEL-2 TYPICAL CHARACTERISTICS. Current Derating a. Power, …
File Format / SizePDF / 339 Kb
SiZ240DT. CHANNEL-2 TYPICAL CHARACTERISTICS. Current Derating a. Power, Junction-to-Case. Note
SiZ240DT CHANNEL-2 TYPICAL CHARACTERISTICS Current Derating a Power, Junction-to-Case Note
SiZ240DT
(25 °C, unless otherwise noted) Axis Title Axis Title 60 10000 40 10000 45 30 ) 1000 1000 ) W rrent (A ine ne ne ne ne ine u r ( 20 30 e C w n 1st li 1st li 2nd l 2nd li 2nd li 2nd l Po rai D 100 100 - 10 I D 15 0 10 0 10 0 25 50 75 100 125 150 0 25 50 75 100 125 150 T - Case Temperature (°C) C T - Case Temperature (°C) C 2nd line
a. The power dissipation PD is based on TJ max. = 25 °C, using junction-to-case thermal resistance, and is more useful in settling the upper dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package limit S19-1100-Rev. B, 30-Dec-2019
10
Document Number: 77182 For technical questions, contact: pmostechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
