ADP1821ABSOLUTE MAXIMUM RATINGSTable 2. Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress Parameter Rating rating only; functional operation of the device at these or any VCC, SHDN, SYNC, FREQ, COMP, SS, FB to −0.3 V to +6 V other conditions above those indicated in the operational GND, PVCC to PGND, BST to SW section of this specification is not implied. Exposure to absolute BST to GND −0.3 V to +30 V maximum rating conditions for extended periods may affect CSL to GND −1 V to +30 V device reliability. DH to GND (VSW − 0.3 V) to (VBST + 0.3 V) Absolute maximum ratings apply individually only, not in DL to PGND −0.3 V to combination. Unless otherwise specified, all other voltages (VPVCC + 0.3 V) are referenced to GND. SW to GND −2 V to +30 V PGND to GND ±2 V θJA, 2-Layer (SEMI Standard Board) 150°C/W ESD CAUTION θJA, 4-Layer (JEDEC Standard Board) 105°C/W Operating Ambient Temperature Range −40°C to +85°C Operating Junction Temperature Range −55°C to +125°C Storage Temperature Range −65°C to +150°C Maximum Soldering Lead Temperature 260°C SIMPLIFIED BLOCK DIAGRAMSHDNADP1821VCCUVLOLOGICFAULTTHERMALBSTGNDSHUTDOWNDHFREQSQSWOSCILLATORSYNCPWMPVCCCOMPRQDLPGNDVCCCSLFB0.6VOV100kΩREFERENCESS0.8VUVPWGD2.5kΩFAULTUVLO 3 THSD -00 310 05 Figure 3. Simplified Block Diagram Rev. C | Page 5 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION SIMPLIFIED BLOCK DIAGRAM PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SOFT START ERROR AMPLIFIER CURRENT-LIMIT SCHEME MOSFET DRIVERS INPUT VOLTAGE RANGE SETTING THE OUTPUT VOLTAGE SWITCHING FREQUENCY CONTROL AND SYNCHRONIZATION COMPENSATION POWER-GOOD INDICATOR THERMAL SHUTDOWN SHUTDOWN CONTROL APPLICATION INFORMATION SELECTING THE INPUT CAPACITOR OUTPUT LC FILTER SELECTING THE MOSFETS SETTING THE CURRENT LIMIT FEEDBACK VOLTAGE DIVIDER COMPENSATING THE VOLTAGE MODE BUCK REGULATOR Type II Compensator Type III Compensator SETTING THE SOFT START PERIOD PCB LAYOUT GUIDELINE RECOMMENDED COMPONENT MANUFACTURERS APPLICATION CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
