Datasheet VCNL3036X01 (Vishay) - 5
ManufacturerVishay
DescriptionHigh Resolution Digital Proximity Sensor With I2C Interface
Pages / Page16 / 5 — VCNL3036X01. TYPICAL PERFORMANCE CHARACTERISTICS. APPLICATION INFORMATION …
File Format / SizePDF / 239 Kb
VCNL3036X01. TYPICAL PERFORMANCE CHARACTERISTICS. APPLICATION INFORMATION Pin Connection with the Host
VCNL3036X01 TYPICAL PERFORMANCE CHARACTERISTICS APPLICATION INFORMATION Pin Connection with the Host
VCNL3036X01
(Tamb = 25 °C, unless otherwise specified) Axis Title Axis Title 1.0 10000 0.22 10000 0.9 V = 3.6 V 0.20 DD 0.8 nsitivity l Se 0.7 V = 3.0 V a 1000 0.18 DD 1000 0.6 ctr ine ine ine 0.16 Spe 0.5 t l t l s s 1 V = 2.5 V 2nd line DD 1 0.4 2nd l 2nd line 2nd line lative upply Current (mA) 100 S 0.14 100 0.3 - - Re 0.2 I DD 0.12 λ) rel 0.1 PS: active force mode enable S( 0 10 0.10 10 400 500 600 700 800 900 1000 1100 -40 -20 0 20 40 60 80 100 120 λ - Wavelength (nm) T - Ambient Temperature (°C) amb 2nd line 2nd line Fig. 4 - Relative Spectral Sensitivity vs. Wavelength Fig. 5 - Supply Current vs. Ambient Temperature (proximity sensor)
VCNL3036X01 integrates proximity sensor and an LED driver with three inputs for external IREDs all together with I2C interface. It is very easy for the baseband (CPU) to access PS output data via I2C interface without extra software algorithms. The hardware schematic is shown in the following diagram.
VCNL3036X01
V 1 8 SDA DD PS data buffer SCL 2 -PD 7 INT S C interface P Output buffer 2 I DSP cillator s O GND 3 Driver 6 IRED1 Temperature compensation IRED3 4 5 IRED2 Fig. 6 - Detailed Block Diagram Rev. 1.0, 12-Aug-2020
5
Document Number: 84937 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
