Datasheet MAX4475, MAX4476, MAX4477, MAX4478, MAX4488, MAX4489 (Maxim) - 8
Manufacturer | Maxim |
Description | SOT23, Low-Noise, Low-Distortion, Wide-Band, Rail-to-Rail Op Amps |
Pages / Page | 17 / 8 — Typical Operating Characteristics (continued). LARGE-SIGNAL VOLTAGE GAIN. … |
File Format / Size | PDF / 2.5 Mb |
Typical Operating Characteristics (continued). LARGE-SIGNAL VOLTAGE GAIN. SUPPLY CURRENT. vs. OUTPUT VOLTAGE SWING
MAX4475–MAX4478/ SOT23, Low-Noise, Low-Distortion, MAX4488/MAX4489 Wide-Band, Rail-to-Rail Op Amps
(VDD = +5V, VSS = 0V, VCM = 0V, VOUT = VDD/2, RL tied to VDD/2, input noise floor of test equipment =10nV/√Hz for all distortion measurements, TA = +25°C, unless otherwise noted.)
LARGE-SIGNAL VOLTAGE GAIN LARGE-SIGNAL VOLTAGE GAIN SUPPLY CURRENT vs. OUTPUT VOLTAGE SWING vs. TEMPERATURE vs. TEMPERATURE
130 140 3.0 RL = 200kΩ PER AMPLIFIER 120 130 RL = 100kΩ MAX4475 toc10 2.5 MAX4475 toc11 MAX4475 toc12 120 110 RL = 10kΩ RL = 20kΩ RL = 2kΩ 110 2.0 100 (dB) 100 (dB) 90 1.5 A V A VOL 90 80 80 1.0 SUPPLY CURRENT (mA) 70 70 VDD = 5V 0.5 60 60 RL REFERENCED TO VDD VOUT = 150mV TO 4.75V 50 50 0 0 50 100 150 200 250 -50 -25 0 25 50 75 100 125 -50 -25 0 25 50 75 100 125 VOUT SWING FROM EITHER SUPPLY (mV) TEMPERATURE (°C) TEMPERATURE (°C)
SUPPLY CURRENT SUPPLY CURRENT INPUT OFFSET VOLTAGE vs. SUPPLY VOLTAGE vs.OUTPUT VOLTAGE vs. SUPPLY VOLTAGE
3.0 3.0 20 PER AMPLIFIER VDD = 5V 15 2.5 2.5 MAX4475 toc13 MAX4475 toc14 MAX4475 toc15 µV) 10 2.0 2.0 VDD = 3V 5 1.5 1.5 0 -5 1.0 1.0 SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) -10 INPUT OFFSET VOLTAGE ( 0.5 0.5 -15 0 0 -20 2.5 3.0 3.5 4.0 4.5 5.0 5.5 0 1 2 3 4 5 2.5 3.0 3.5 4.0 4.5 5.0 5.5 SUPPLY VOLTAGE (V) OUTPUT VOLTAGE (V) SUPPLY VOLTAGE (V)
MAX4475–MAX4478 MAX4488/MAX4489 GAIN AND PHASE vs. FREQUENCY GAIN AND PHASE vs. FREQUENCY
60 MAX4475 toc16 180 60 MAX4475 toc17 180 VDD = 3V OR 5V 50 144 50 GAIN 144 RL = 50kΩ GAIN 40 CL = 20pF 108 40 108 A 30 V = +1000V/V 72 30 72 20 36 20 36 10 0 10 0 0 -36 GAIN (dB) GAIN (dB) 0 -36 -10 PHASE (degrees) -72 -10 PHASE (degrees) -72 V -20 -108 -20 DD = 3V OR 5V PHASE R -108 L = 50kΩ PHASE -30 -144 -30 CL = 20pF -144 AV = +1000V/V -40 -180 -40 -180 100 1k 10k 100k 1M 10M 100M 100 1k 10k 100k 1M 10M 100M INPUT FREQUENCY (Hz) INPUT FREQUENCY (Hz) www.maximintegrated.com Maxim Integrated │ 8
