Datasheet MAX4475, MAX4476, MAX4477, MAX4478, MAX4488, MAX4489 (Maxim) - 10
Manufacturer | Maxim |
Description | SOT23, Low-Noise, Low-Distortion, Wide-Band, Rail-to-Rail Op Amps |
Pages / Page | 17 / 10 — Typical Operating Characteristics (continued). MAX4488/MAX4489. … |
File Format / Size | PDF / 2.5 Mb |
Typical Operating Characteristics (continued). MAX4488/MAX4489. MAX4475–MAX4478. TOTAL HARMONIC DISTORTION PLUS NOISE
MAX4475–MAX4478/ SOT23, Low-Noise, Low-Distortion, MAX4488/MAX4489 Wide-Band, Rail-to-Rail Op Amps
(VDD = +5V, VSS = 0V, VCM = 0V, VOUT = VDD/2, RL tied to VDD/2, input noise floor of test equipment =10nV/√Hz for all distortion measurements, TA = +25°C, unless otherwise noted.)
MAX4488/MAX4489 MAX4475–MAX4478 MAX4475–MAX4478 TOTAL HARMONIC DISTORTION PLUS NOISE LARGE-SIGNAL PULSE RESPONSE SMALL-SIGNAL PULSE RESPONSE vs. FREQUENCY
MAX4475 toc27 MAX4475 toc28 1 FILTER BW = 80kHz RL = 10kΩ TO GND 0.6V R1 = 2.43kΩ, R2 = 10kΩ MAX4475 toc26 2.5V 0.1 VOUT = 2.75VP-P 20mV/div 0.01 THD + N (%) A 0.001 V = +5, VDD = 3V 0.5V 0.5V AV = +5, VDD = 5V 0.0001 0 5k 10k 15k 20k 1µs/div 4µs/div FREQUENCY (Hz) VDD = 3V, RL = 10kΩ, CL = 100pF VDD = 3V, RL = 10kΩ, CL = 100pF VIN = 2V VIN = 100mV PULSE
MAX4488/MAX4489 MAX4488/MAX4489 MAX4477/MAX4478/MAX4489 LARGE-SIGNAL PULSE RESPONSE SMALL-SIGNAL PULSE RESPONSE
MAX4475 toc29 MAX4475 toc30
CROSSTALK vs. FREQUENCY
-20 -30 MAX4475 toc31 1.6V V -40 OUT 50mV/div V -50 OUT 1.5V 200mV/div -60 CROSSTALK (dB) -70 -80 -90 1µs/div 1µs/div 10 100 1000 10k 100k 1M 10M 100M VDD = 3V, RL = 10kΩ, CL = 50pF VDD = 3V, RL = 10kΩ, CL = 50pF FREQUENCY (Hz) VIN = 20mV PULSE, AV = +5V/V VIN = 20mV PULSE, AV = +5V/V www.maximintegrated.com Maxim Integrated │ 10
