Datasheet WP710A10YD5V (Kingbright)
ManufacturerKingbright
DescriptionT-1 (3mm) Solid State Lamp
Pages / Page5 / 1 — WP710A10YD5V. DESCRIPTIONS. PACKAGE DIMENSIONS. FEATURES. APPLICATIONS. …
File Format / SizePDF / 321 Kb
WP710A10YD5V. DESCRIPTIONS. PACKAGE DIMENSIONS. FEATURES. APPLICATIONS. ATTENTION. SELECTION GUIDE. Iv (mcd) V = 5V. View. ing Angle
Datasheet WP710A10YD5V Kingbright
WP710A10YD5V
DESCRIPTIONS PACKAGE DIMENSIONS
z The Yellow source color devices are made with Gallium Arsenide Phosphide on Gallium Phosphide Yellow Light Emitting Diode z Electrostatic discharge and power surge could damage the LEDs z It is recommended to use a wrist band or anti- electrostatic glove when handling the LEDs z All devices, equipments and machineries must be electrically grounded
FEATURES
z Low power consumption z Popular T-1 diameter package z General purpose leads z Reliable and rugged z Long life - solid state reliability z Available on tape and reel z 5V internal resistor z RoHS compliant
z Status indicator z Illuminator Notes: z Signage applications 1. All dimensions are in millimeters (inches). 2. Tolerance is ±0.25(0.01") unless otherwise noted. z Decorative and entertainment lighting 3. Lead spacing is measured where the leads emerge from the package. 4. The specifications, characteristics and technical data described in the datasheet are subject to change z Commercial and residential architectural lighting without prior notice.
ATTENTION
Observe precautions for handling electrostatic discharge sensitive devices
SELECTION GUIDE Iv (mcd) V = 5V
[2]
View ing Angle
[1]
Emitting Color Part Number Lens Type (Material) Min. Typ. 2θ1/2
WP710A10YD5V ■ Yellow (GaAsP/GaP) Yellow Diffused 7 15 50° Notes: 1. θ1/2 is the angle from optical centerline where the luminous intensity is 1/2 of the optical peak value. 2. Luminous intensity / luminous flux: +/-15%. 3. Luminous intensity value is traceable to CIE127-2007 standards. © 2019 Kingbright. All Rights Reserved. Spec No: DSAL0566 / 1101029092 Rev No: V.10B Date: 11/19/2019 Page 1 / 5
