Datasheet MAX4389, MAX4390, MAX4392–MAX4396 (Maxim) - 9
ManufacturerMaxim
DescriptionUltra-Small, Low-Cost, 85MHz Op Amps with Rail-to-Rail Outputs and Disable
Pages / Page17 / 9 — Typical Operating Characteristics (continued). SMALL-SIGNAL BANDWIDTH. …
File Format / SizePDF / 2.5 Mb
Typical Operating Characteristics (continued). SMALL-SIGNAL BANDWIDTH. vs. LOAD RESISTANCE. OPEN-LOOP GAIN vs. RESISTIVE LOAD
Typical Operating Characteristics (continued) SMALL-SIGNAL BANDWIDTH vs LOAD RESISTANCE OPEN-LOOP GAIN vs RESISTIVE LOAD
MAX4389/MAX4390/ Ultra-Small, Low-Cost, 85MHz Op Amps with MAX4392–MAX4396 Rail-to-Rail Outputs and Disable
(VCC = 5V, VEE = -5V, VCM = 0V, AVCL = 1V/V, RL = 100Ω to GND, GND = 0, TA = +25°C, unless otherwise noted.)
SMALL-SIGNAL BANDWIDTH vs. LOAD RESISTANCE OPEN-LOOP GAIN vs. RESISTIVE LOAD CROSSTALK vs. FREQUENCY
140 80 0 -10 120 70 MAX4389 toc25 MAX4389 toc26 MAX4389 toc27 -20 100 60 -30 50 80 -40 40 -50 60 30 -60 BANDWIDTH (MHz) CROSSTALK (dB) 40 OPEN-LOOP GAIN (dBc) -70 20 -80 20 10 -90 0 0 -100 0 100 200 300 400 500 600 700 800 100 1k 10k 100k 1M 10M 100M 1G RLOAD (Ω) RLOAD (Ω) FREQUENCY (Hz)
INPUT OFFSET VOLTAGE DISABLE RESPONSE vs. TEMPERATURE
8 5V 7 MAX4389 toc28 MAX4389 toc29 DISABLE 6 0V 5 4 1.5V 3 VOUT 2 INPUT OFFSET VOLTAGE (mV) 0V 1 0 200ns/div -50 -25 0 25 50 75 100 TEMPERATURE (°C)
INPUT BIAS CURRENT SUPPLY CURRENT vs. TEMPERATURE vs. TEMPERATURE
8 8 7 7 MAX4389 toc30 MAX4389 toc31 6 6 5 5 4 4 3 3 INPUT BIAS CURRENT (µA) 2 SUPPLY CURRENT (mA) 2 1 1 0 0 -50 -25 0 25 50 75 100 -50 -25 0 25 50 75 100 TEMPERATURE (°C) TEMPERATURE (°C) www.maximintegrated.com Maxim Integrated │ 9
