Datasheet 2ED24427N01F (Infineon) - 6
ManufacturerInfineon
Description10 A dual -channel low-side gate driver IC
Pages / Page21 / 6 — 2ED24427N01F. 10 A dual-channel low-side gate driver IC. Electrical …
Revision02_00
2ED24427N01F. 10 A dual-channel low-side gate driver IC. Electrical parameters. 4.1. Absolute maximum ratings. Table 3. Symbol
2ED24427N01F 10 A dual-channel low-side gate driver IC Electrical parameters 4.1 Absolute maximum ratings Table 3 Symbol
2ED24427N01F 10 A dual-channel low-side gate driver IC 4 Electrical parameters 4.1 Absolute maximum ratings
Absolute Maximum Ratings indicate sustained limits beyond which damage to the device may occur. All voltage parameters are absolute voltages referenced to COM lead. Stresses beyond those listed under "Absolute Maximum Ratings" may cause permanent damage to the device. These are stress ratings only; and functional operation of the device at these or any other condition beyond those indicated in the ―Recommended Operating Conditions‖ is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. The thermal resistance and power dissipation ratings are measured under board mounted and still air conditions. Ambient temperature (TA) is 25°C, unless otherwise specified.
Table 3 Absolute maximum ratings Symbol Definition Min Max Units
VCC Fixed supply voltage – 0.3 24 VO Output voltage – 0.3 24 V VIN Logic input voltage – 0.3 5.5 VEN Logic enable voltage – 0.3 5.5 RthJC Thermal resistance, junction to case — 4 °C/W TJ Junction temperature — 150 TS Storage temperature – 55 150 °C TL Lead temperature (soldering, 10 seconds) — 300
4.2 Recommended operating conditions
For proper operation, the device should be used within the recommended conditions. All voltage parameters are absolute voltages referenced to COM.
Table 4 Recommended operating conditions Symbol Definition Min Max Units
VCC Fixed supply voltage 5 20 VO Output voltage 0 VCC V VIN Logic input voltage 0 5 VEN Logic enable voltage 0 5 TA Ambient temperature – 40 125 °C RG External gate resistance 2.5 Ω CBP VCC to COM bypass capacitance – X7R dielectric type 1 µF Datasheet 6 of 21 V 2.0 www.infineon.com/gdLowSide 2019-11-10
