Datasheet VEMD8081 (Vishay)
ManufacturerVishay
DescriptionSilicon PIN Photodiode
Pages / Page6 / 1 — VEMD8081. Silicon PIN Photodiode. FEATURES. LINKS TO ADDITIONAL …
File Format / SizePDF / 156 Kb
VEMD8081. Silicon PIN Photodiode. FEATURES. LINKS TO ADDITIONAL RESOURCES. D 3. 3 D. APPLICATIONS. DESCRIPTION. PRODUCT SUMMARY. Ira (μA)
Datasheet VEMD8081 Vishay
VEMD8081
Silicon PIN Photodiode FEATURES
• Package type: surface-mount • Package form: top view • Dimensions (L x W x H in mm): 4.8 x 2.5 x 0.48 • Radiant sensitive area (in mm2): 5.4 • 0.48 mm low profile package • Enhanced sensitivity for visible light • Suitable for visible and near infrared radiation • Angle of half sensitivity: ϕ = ± 65°
• Floor life: 168 h, MSL 3, according to J-STD-020 • Material categorization: for definitions of compliance
D 3 3 D
please see www.vishay.com/doc?99912 3D Models
APPLICATIONS DESCRIPTION
• High speed photo detector VEMD8081 is a high speed and high sensitive PIN • Wearables photodiode with enhanced sensitivity for visible light. It is a low profile surface-mount device (SMD) including the chip with a 5.4 mm2 sensitive area detecting visible and near infrared radiation.
PRODUCT SUMMARY Ira (μA)
ϕ λ
COMPONENT at E 0.1 e = 1.0 mW/cm2,
λ
(°) (nm) = 850 nm, VR = 5.0 V
VEMD8081 33 ± 65 350 to 1100
Note
• Test conditions see table “Basic Characteristics”
ORDERING INFORMATION ORDERING CODE PACKAGING REMARKS PACKAGE FORM
VEMD8081 Tape and reel MOQ: 5000 pcs, 5000 pcs/reel Top view
Note
• MOQ: minimum order quantity
ABSOLUTE MAXIMUM RATINGS
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL VALUE UNIT
Reverse voltage VR 20 V Operating temperature range Tamb -40 to +85 °C Storage temperature range Tstg -40 to +85 °C Soldering temperature According to reflow solder profile Fig. 8 Tsd 260 °C ESD safety HBM ± 2000 V, 1.5 kΩ, 100 pF, 3 pulses ESDHBM ≥ 2 kV Rev. 1.0, 07-Oct-2020
1
Document Number: 80218 For technical questions, contact: detectortechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
