Datasheet ADA4098-1 (Analog Devices) - 9
Description50 V, 1 MHz, 165 µA, Robust Over-The-Top Precision Op Amp
Pages / Page27 / 9 — Preliminary Technical Data. ADA4098-1. TYPICAL PERFORMANCE CHARACTERISTICS
RevisionPrA
Preliminary Technical Data ADA4098-1 TYPICAL PERFORMANCE CHARACTERISTICS
Figure 5. Supply Current vs. Supply Voltage Figure 8. Shutdown Supply Current vs. Supply Voltage Figure 6. Supply Current vs. Temperature Across Various Supply Voltages Figure 9. Typical Distribution of Input Offset Voltage, VSY = 5 V Figure 7. Supply Current vs. VSHDN with Respect to −VS Figure 10. Typical Distribution of Input Offset Voltage with VSY = ±15 V Rev. PrA | Page 9 of 27 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TYPICAL APPLICATION CIRCUIT TABLE OF CONTENTS SPECIFICATIONS 5 V SUPPLY ±15 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT PROTECTION OVER-THE-TOP OPERATION CONSIDERATIONS OUTPUT SHUTDOWN PIN (SHDN) APPLICATIONS INFORMATION LARGE RESISTOR GAIN OPERATION RECOMMENDED VALUES FOR VARIOUS GAINS NOISE DISTORTION POWER DISSIPATION AND THERMAL SHUTDOWN CIRCUIT LAYOUT CONSIDERATIONS POWER SUPPLY BYPASSING GROUNDING ESD PROTECTION WHEN POWERED RELATED PRODUCTS TYPICAL APPLICATIONS OUTLINE DIMENSIONS
