Datasheet ADA4098-1 (Analog Devices) - 10
Description50 V, 1 MHz, 165 µA, Robust Over-The-Top Precision Op Amp
Pages / Page27 / 10 — ADA4098-1. Preliminary Technical Data
RevisionPrA
ADA4098-1 Preliminary Technical Data
Figure 11. Typical Distribution of Input Offset Voltage with VSY = ±25 V Figure 14. Offset Voltage vs. Temperature with VSY = ±25 V Figure 12. Offset Voltage vs. Temperature with VSY = 5 V Figure 15. Midsupply Input Bias Current vs. Temperature with VSY = 5 V Figure 13. Offset Voltage vs. Temperature with VSY = ±15 V Figure 16. Midsupply Input Bias Current vs. Temperature with VSY = ±15 V Rev. PrA | Page 10 of 27 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TYPICAL APPLICATION CIRCUIT TABLE OF CONTENTS SPECIFICATIONS 5 V SUPPLY ±15 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT PROTECTION OVER-THE-TOP OPERATION CONSIDERATIONS OUTPUT SHUTDOWN PIN (SHDN) APPLICATIONS INFORMATION LARGE RESISTOR GAIN OPERATION RECOMMENDED VALUES FOR VARIOUS GAINS NOISE DISTORTION POWER DISSIPATION AND THERMAL SHUTDOWN CIRCUIT LAYOUT CONSIDERATIONS POWER SUPPLY BYPASSING GROUNDING ESD PROTECTION WHEN POWERED RELATED PRODUCTS TYPICAL APPLICATIONS OUTLINE DIMENSIONS
