Wide Supply Dual, 17 MHz, Rail-to-Rail FET Input Amplifier
Pages / Page
20 /10 — AD823A. Data Sheet. +VS = +5V. (V). 0.1%. 0.01%. E (nV. TO V V. OIS. IZE. …
Revision
B
PDF / 521 Kb
AD823A. Data Sheet. +VS = +5V. (V). 0.1%. 0.01%. E (nV. TO V V. OIS. IZE. OLTA. T V. T S –6. U TP –8. VS = ±15V. CL = 20pF. –10. 100. 10k. 100k. 200. 300. 400. 500
AD823AData Sheet5010+VS = +5V8(V)40N1%0.1%z)WH6HO/√S0.01%430E (nVTO V V2OIS0NOM0GEFR20–2IZEOLTAS0.1%PT V–4TEPU1%0.01%INT S –6U TP –8VS = ±15VOUCL = 20pF10–10101001k10k100k1M 016 100200300400500600700 020 FREQUENCY (Hz)SETTLING TIME (ns) 09439- 09439- Figure 19. Input Voltage Noise vs. Frequency Figure 22. Output Step Size vs. Settling Time (Inverter) 1001VS = ±2.5VVCS = ±15VL = 20pF90R0L = 2kΩG = +1+V)80S = +5VdB (–1IN70B)GAd–260RR (–55°C-LOOP+25°CCMD+125°C50E–3LOS C40–430–520101001k10k100k1M10M0.303.276.249.21 12.18 15.15 18.12 21.09 24.06 27.03 30.00 061 052 FREQUENCY (Hz)FREQUENCY (MHz) 09439- 09439- Figure 20. Closed-Loop Bandwidth vs. Temperature Figure 23. Common-Mode Rejection Ratio vs. Frequency 10010V+VS = +5VS = +5VG = +1) V (10)GE1(ΩOLTA1ANCEVT IS STION0.1EAVRS TO VOH25°CT R0.1TUUATPT SOUU 0.010.01TPVOLOU25°C0.0010.0011001k10k100k1M10M 053 0.1110100 021 FREQUENCY (Hz)LOAD CURRENT (mA) 09439- 09439- Figure 21. Output Resistance vs. Frequency, +VS = +5 V, G = +1 Figure 24. Output Saturation Voltage vs. Load Current Rev. B | Page 10 of 20 Document Outline Features Applications General Description Connection Diagram Revision History Specifications 5 V Operation 3.3 V Operation ±15 V Operation Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Output Impedance Applications Information Input Characteristics Output Characteristics Wideband Photodiode Preamp Active Filter Maximizing Performance Through Proper Layout Outline Dimensions Ordering Guide
