Datasheet AD712 (Analog Devices) - 6
DescriptionPrecision, Low Cost, High Speed, BiFET Dual Op Amp
Pages / Page20 / 6 — AD712. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. V) 15. G (. (mA). …
RevisionI
File Format / SizePDF / 569 Kb
AD712. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. V) 15. G (. (mA). WIN. S GE 10. CURRE 4. OLTA. RL = 2kΩ. 25°C. T V PU. ESCE UI. IN 5. Q 3
AD712 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS V) 15 G ( (mA) WIN S GE 10 CURRE 4 OLTA RL = 2kΩ 25°C T V PU ESCE UI IN 5 Q 3
AD712 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 20 6 V) 15 5 G ( (mA) WIN NT S GE 10 CURRE 4 OLTA RL = 2kΩ NT 25°C T V PU ESCE UI IN 5 Q 3 0 2 0 5 10 15 20
002
0 5 10 15 20
005
SUPPLY VOLTAGE ± V
00823-
SUPPLY VOLTAGE ± V
00823- Figure 2. Input Voltage Swing vs. Supply Voltage Figure 5. Quiescent Current vs. Supply Voltage
20 106 s) 107 V) G ( 15 (Amp +VOUT 0) WIN = 108 S –VOUT GE (V CM 10 NT 109 OLTA RL = 2kΩ T V 25°C U CURRE 1010 TP AS 5 OU BI UT 1011 INP 0 0 5 10 15 20
003
1012–60 –40 –20 0 20 40 60 80 100 120 140
006
SUPPLY VOLTAGE ± V
00823-
TEMPERATURE (°C)
00823- Figure 3. Output Voltage Swing vs. Supply Voltage Figure 6. Input Bias Current vs. Temperature
30 100 p) 25 V p- ) 10 G ( (Ω 20 WIN S ±15V SUPPLIES GE 15 PEDANCE 1.0 IM OLTA PUT T V 10 U UT TP O 0.1 OU 5 0 0.01 10 100 1k 10k
004
1k 10k 100k 1M 10M
007
LOAD RESISTANCE (Ω) FREQUENCY (Hz)
00823- 00823- Figure 4. Output Voltage Swing vs. Load Resistance Figure 7. Output Impedance vs. Frequency Rev. I | Page 6 of 20 Document Outline FEATURES CONNECTION DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS SETTLING TIME OPTIMIZING SETTLING TIME OP AMP SETTLING TIME—A MATHEMATICAL MODEL APPLICATIONS INFORMATION GUARDING DAC CONVERTER APPLICATIONS NOISE CHARACTERISTICS DRIVING THE ANALOG INPUT OF AN ADC DRIVING A LARGE CAPACITIVE LOAD FILTERS ACTIVE FILTER APPLICATIONS SECOND-ORDER LOW-PASS FILTER 9-POLE CHEBYCHEV FILTER OUTLINE DIMENSIONS ORDERING GUIDE
