Datasheet LTC2066, LTC2067, LTC2068 (Analog Devices) - 2
Description | 10µA Supply Current, Low IB, Zero-Drift Operational Amplifier |
Pages / Page | 30 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION … |
Revision | B |
File Format / Size | PDF / 5.0 Mb |
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
LTC2066/LTC2067/LTC2068
Total Supply Voltage (V+ to V–) ..5.5V Operating and Specified Temperature Range (Note 4) Differential Input Current (+IN to –IN) (Note 2) .. ±10mA LTC2066I/LTC2067I/LTC2068I ..–40°C to 85°C Differential Input Voltage (+IN to –IN) ..5.5V LTC2066H/LTC2067H/LTC2068H .. –40°C to 125°C Input Voltage +IN, –IN, SHDN ...(V–) – 0.3V to (V+) + 0.3V Maximum Junction Temperature .. 150°C Input Current +IN, –IN, SHDN (Note 2) .. ±10mA Storage Temperature Range .. –65°C to 150°C Output Short-Circuit Duration (Note 3) ...Thermally Limited
PIN CONFIGURATION
LTC2066 LTC2067 LTC2068 TOP VIEW TOP VIEW A +IN 1 6 V+ TOP VIEW SHDN OUT OUTD NC 16 15 14 13 V– 2 + 5 SHDN OUTA 1 8 V+ – –INA 1 12 –IND –INA 2 7 OUTB –IN 3 4 OUT A +INA 3 6 –INB +INA 2 11 +IND 17 V– 4 B 5 +INB V+ 3 10 V– SC6 PACKAGE 4 9 +INB +INC 6-LEAD PLASTIC SC70 MS8 PACKAGE 5 6 7 8 θ 8-LEAD PLASTIC MSOP JA = 265°C/W (Note 5) θ JA = 163°C/W, θJC = 40°C/W (Note 5) –INB OUTB OUTC –INC QFN16 PACKAGE 16-LEAD (3mm × 3mm) PLASTIC QFN θJA = 68°C/W (NOTE 5) EXPOSED PAD (PIN 17) MUST BE CONNECTED TO V–(PIN 10) LTC2066 LTC2067 LTC2068 TOP VIEW TOP VIEW TOP VIEW OUTA 1 10 V+ OUTA 1 14 OUTD –INA 2 13 –IND OUT 1 5 V+ –INA 2 9 OUTB A A D +INA 3 12 +IND V– 2 +INA 3 11 8 –INB + – B V+ 4 11 V– +IN V– 4 7 +INB 3 4 –IN NC 5 6 SHDN +INB 5 10 +INC B C S5 PACKAGE –INB 6 9 –INC 5-LEAD PLASTIC TSOT-23 DD PACKAGE OUTB 7 8 OUTC θJA = 215°C/W (Note 5) 10-LEAD (3mm × 3mm) PLASTIC DFN θ TSSOP14 PACKAGE JA = 43°C/W, θJC = 5.5°C/W (Note 5) EXPOSED PAD (PIN 11) IS CONNECTED 14-LEAD PLASTIC TSSOP TO V– (PIN 4) (PCB CONNECTION OPTIONAL) θJA = 100°C/W (NOTE 5)
LTC2066ISC6#TRMPBF LTC2066ISC6#TRPBF LHDB 6-Lead Plastic SC70 –40°C to 85°C LTC2066HSC6#TRMPBF LTC2066HSC6#TRPBF LHDB 6-Lead Plastic SC70 –40°C to 125°C LTC2066IS5#TRMPBF LTC2066IS5#TRPBF LTHCZ 5-Lead Plastic TSOT-23 –40°C to 85°C LTC2066HS5#TRMPBF LTC2066HS5#TRPBF LTHCZ 5-Lead Plastic TSOT-23 –40°C to 125°C LTC2067IMS8#PBF LTC2067IMS8#TRPBF LTHDC 8-Lead Plastic MSOP –40°C to 85°C LTC2067HMS8#PBF LTC2067HMS8#TRPBF LTHDC 8-Lead Plastic MSOP –40°C to 125°C LTC2067IDD#PBF LTC2067IDD#TRPBF LHDD 10-Lead (3mm × 3mm) Plastic DFN –40°C to 85°C LTC2067HDD#PBF LTC2067HDD#TRPBF LHDD 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LTC2068IUD#PBF LTC2068IUD#TRPBF LHKV 16-Lead (3mm × 3mm) Plastic QFN –40°C to 85°C LTC2068HUD#PBF LTC2068HUD#TRPBF LHKV 16-Lead (3mm × 3mm) Plastic QFN –40°C to 125°C LTC2068IF#PBF LTC2068IF#TRPBF LTC2068 14-Lead TSSOP –40°C to 85°C LTC2068HF#PBF LTC2068HF#TRPBF LTC2068 14-Lead TSSOP –40°C to 125°C Contact the factory for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Parts ending with PBF are RoHS and WEEE compliant. Tape and reel specifications. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. Rev. B 2 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Revision History Typical Application Related Parts
