Datasheet AD8041 (Analog Devices) - 8
Description | 160 MHz Rail-to-Rail Amplifier with Disable |
Pages / Page | 16 / 8 — AD8041. S = 5V. G = –1. T = +125. L = 2k. TO 2.5V. L = 5pF. S = 3V, 0.1%. … |
Revision | B |
File Format / Size | PDF / 285 Kb |
AD8041. S = 5V. G = –1. T = +125. L = 2k. TO 2.5V. L = 5pF. S = 3V, 0.1%. G = +1. T = +25. S =. 5V, 0.1%. T = –55. TIME (ns). VS = 3V, 1%
AD8041 5 50 V 4 S = 5V G = –1 R T = +125
ⴗ
C L = 2k
TO 2.5V 3 C V L = 5pF S = 3V, 0.1% G = +1 40 2 T = +25
ⴗ
C V 1 S =
ⴞ
5V, 0.1% 0 30 T = –55
ⴗ
C –1 TIME (ns) VS = 3V, 1% –2 20 CLOSED-LOOP GAIN (dB) –3 V –4 S =
ⴞ
5V, 1% 10 –5 1 10 100 500 0.5 1 1.5 2 FREQUENCY (MHz) INPUT STEP (V p-p)
TPC 13. Closed-Loop Frequency Response TPC 16. Settling Time vs. Input Step vs. Temperature
5 –10 4 G = +1 V –20 R S = 3V L = 2k
R VS = +3V AND
ⴞ
5V L AND CL TO 1.5V 3 CL = 5pF –30 2 VS = 5V –40 RL AND CL TO 2.5V 1 –50 0 –60 VS =
ⴞ
5V –1 –70 CMRR (dB) –2 –80 CLOSED-LOOP GAIN (dB) –3 –90 –4 –100 –5 –110 1 10 100 500 0.01 0.1 1 10 100 500 FREQUENCY (MHz) FREQUENCY (MHz)
TPC 14. Closed-Loop Frequency Response vs. Supply TPC 17. CMRR vs. Frequency
1000 100 V G = +1 S = 5V VS = 5V )
ⴗ
C
10 , +125 100 OH
ⴗ
C , –55 +5V – V OH 1
ⴗ
C +5V – V , +125 VOL , –55
ⴗ
C 0.1 10 VOL OUTPUT RESISTANCE ( 0.01 OUTPUT SATURATION VOLTAGE (mV) 0 0.01 0.1 1 10 100 500 0.001 0.01 0.1 1 10 10 FREQUENCY (MHz) LOAD CURRENT (mA) 0
TPC 15. Output Resistance vs. Frequency TPC 18. Output Saturation Voltage vs. Load Current –8– REV. B Document Outline FEATURES APPLICATIONS PRODUCT DESCRIPTION CONNECTION DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ORDERING GUIDE Typical Performance Characteristics Overdrive Recovery Circuit Description Output Impedance Disable Operation Single-Supply A/D Conversion APPLICATIONS RGB Buffer Single-Supply Composite Video Line Driver Sync Stripper Layout Considerations OUTLINE DIMENSIONS Revision History
