Datasheet AD8041 (Analog Devices) - 10 Manufacturer Analog Devices Description 160 MHz Rail-to-Rail Amplifier with Disable Pages / Page 16 / 10 — AD8041. 4.840V MAX. 2.60V. VS = 5V G = +1. L = 2k. L = 150. TO 2.5V. … Revision B File Format / Size PDF / 285 Kb Document Language English
AD8041. 4.840V MAX. 2.60V. VS = 5V G = +1. L = 2k. L = 150. TO 2.5V. 2.55V. VL = 5pF. 2.50V. 2.45V. 0.111V MIN. 2.40V. 200. 50mV. 40ns. 3.0V. 4.741V MAX
Model Line for this Datasheet Text Version of Document AD8041 5V 4.840V MAX 2.60V VS = 5V G = +1 4V R R L = 2k ⍀L = 150 ⍀TO 2.5V 2.55V VL = 5pF 3V 2.50V 2V 2.45V 1V 0.111V MIN 2.40V 1V 200 s 50mV 40ns 0V a. TPC 27. 100 mV Step Response, VS = 5 V, G = +15V 3.0V 4.741V MAX VIN = 3V p-p 2.5V f = 0.1MHz 4V R R L = 2k ⍀L = 150 ⍀TO GND VS = 3V 2.0V G = –1 3V 1.5V 2V 1.0V 1V 0.5V 0.043V MIN 1V 200 s 500mV 2 s 0V 0V b. TPC 25. Output Swing vs. Load Reference Voltage, TPC 28. Output Swing, VS = 3 V, VIN = 3 V p-p VS = 5 V, G = –14.5V 3.0V VS = 5V VIN = 2.8V p-p G = +2 2.5V f = 0.8MHz R R 3.5V L = 2k ⍀L = 2k ⍀VIN = 1V p-p V 2.0V S = 3V G = –1 2.5V 1.5V 1.0V 1.5V 0.5V 1V 40ns 500mV 2 s 0.5V 0V TPC 26. One Volt Step Response, VS = 5 V, G = +2 TPC 29. Output Swing, VS = 3 V, VIN = 2.8 V p-p –10– REV. B Document Outline FEATURES APPLICATIONS PRODUCT DESCRIPTION CONNECTION DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ORDERING GUIDE Typical Performance Characteristics Overdrive Recovery Circuit Description Output Impedance Disable Operation Single-Supply A/D Conversion APPLICATIONS RGB Buffer Single-Supply Composite Video Line Driver Sync Stripper Layout Considerations OUTLINE DIMENSIONS Revision History
